1. brnc's Avatar
    Wondering if the new generation of phones require this to be done any longer. I need blue tooth for my car, wifi at home, and gps for the weather and maps apps, but at other times do not. How much battery will I really save taking the effort to manage these features? Are phones (specifically the s4) smart enough now to not need this kind of active management?
    04-29-2013 01:49 PM
  2. Reformed IOS User's Avatar
    I rarely use WIfi since I have an unlimited plan - so I keep it off
    I don't use GPS much either - you can enter a static place to show the weather
    keep blue tooth on since I am in my car daily
    these functions are easy to toggle on and off with the pull down menu
    much easier than it was on my iphone
    04-29-2013 01:58 PM
  1. Replies: 8
    Last Post: 06-04-2014, 03:26 PM
  2. Replies: 2
    Last Post: 10-22-2012, 07:03 PM
  3. Replies: 6
    Last Post: 07-01-2012, 04:05 PM
  4. Is there a fix allowing for encryption and gps to work together?
    By chmik3b0 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 11-02-2011, 03:34 PM
  5. Rooting and SetCPU to Save Battery Life
    By mscalero in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 09-22-2010, 11:02 AM
