I need a little bit of help with this and for some reason I haven't been able to find any solutions with my research...
Background is, I have a Samsung Galaxy S4 with AT&T, and drive a 2007 Honda Civic EX. The EX has a Lighter, and AUX port, but no direct USB port. So I'm looking to be able to plug in my S4 (hopefully with one cord) and be able to play my music AND charge the phone.
Of course, I could use the two court option. A Male AUX to Male AUX, with a Lighter to USB, then a USB to MicroUSB, and this solves the solution. Well, it's bulky, and gives an awkward resistance when trying to use the phone to switch songs/etc which is more then likely due to the ports being on either side of the device.
I would use bluetooth, but the Civic isn't built in with BT, and I've heard it's not too reliable anyways.
Now, what I have come up with (and if there's more ideas let me know too, I'm also open to other ways) but is two different options.
1)A MicroUSB to USB and AUX (One Cable, single on one end, and dual on the other) (Is it even possible to play music through the MicroUSB port?)
or
2)An AUX to MicroUSB (which even then I don't believe will charge it will it?)
I've not able to find either one of these. So that's where I'm looking for your help. Either different ideas on how to accomplish my goal, or where I may be able to find one of the two cords.
Thanks in advance!
or
Thanks in advance!
