1. thestardawg's Avatar
    Is anyone else using Comfort Level? Mine is showing that the room temp is 80 degrees with 70% humidity. Thermostat shows a cool 72 degrees.
    How does one calibrate this?
    04-30-2013 09:59 AM
  2. dwhitman's Avatar
    I'm wondering if the temperature would be more accurate if you put the phone in airplane mode for 30 minutes before checking? I'm guessing heat from the CPU and/or radio is warming the phone enough that the reported number is accurate...for the location of the sensor, inside the phone.
    I wouldn't hold out much hope for good RH readings. Humidity is notoriously difficult to measure accurately even with a dedicated instrument.
    04-30-2013 10:18 AM
  3. steveh552's Avatar
    Is this built into the phone? I cannot find it
    ______
    Sent from my mobile device
    04-30-2013 06:29 PM
  4. archer75's Avatar
    Yeah it's not remotely accurate. Not once. Not sure why I need it to tell me i'm comfortable so no big loss.
    04-30-2013 06:30 PM
  5. thelaststraw05's Avatar
    Yeah, I've not quite figured out what this feature would be good for. I've never sat there thinking, "You know, my phone would be much better if it could tell me what the temperature and humidity are right now. I think I'm comfortable, but I'm not quite sure."
    I was kinda hoping that developers would find a cool use for it, but I don't have any ideas of what that would be.
    04-30-2013 07:41 PM
  1. Hyperion 4200mah Battery showing wrong levels?
    By smooth4lyfe in forum Samsung Galaxy S III Accessories
    Last Post: 11-26-2012, 06:07 PM
  2. Desk Clock Temp Wrong
    By herbmmm in forum Verizon Droid Incredible
    Last Post: 11-01-2010, 10:47 AM
  3. Replies: 5
    Last Post: 07-27-2010, 07:42 AM
  4. New Emails Date showing WRONG date
    By str8sNUTS in forum Motorola Droid
    Last Post: 11-30-2009, 07:57 AM
  5. Weather showing wrong location
    By chickenlump in forum HTC Hero
    Last Post: 11-27-2009, 06:46 PM
