Light Flow 3.8.0 is running on my Galaxy S3.
The LED blinks just fine, but is not terminated when I look at the text message, phone call, etc that it is notifying me about.
This only started with I decided to use FOLDERS on my application.
Once I started putting my application icons in Folders, my S3 would shout out every time I opened or closed any folder.
So I had to turn OFF the "Accessibility | Services | Light Flow Lite".
(The "Accessibility | Services | TalkBack" was already off.)
With the "Light Flow Lite" service off, then at least the "shout outs" stop, but the LED notifications do not terminate like the used to, before I started using Folders.
I did find one annoying fix...
I can open up Light Flow, and only then will the blinking stop.
So every time I get an LED notification, then I have to look at the message that the notification is about, and then open up Light Flow to get the blinking to stop.
Lots of extra clicking to terminate each notification.
Are there any other similar-but-better applications out there?
