09-12-2014 11:17 PM
28 12
tools
  1. Davidjacobs21's Avatar
    I have the setting to on, and after seeing the review videos, all the places where they should work, they dont. Anybody have any ideas
    05-01-2013 07:56 AM
  2. perrochingon's Avatar
    Yeah I can't seem to get mine working either. I can use air gestures while viewing photos and I am able to swipe left and right. But I can't answer a phone call or wake my phone by swiping my hand over the phone. I also can't get the air view feature to work either. I'm curious to see how many people are also experiencing this issue.
    05-01-2013 08:20 AM
  3. Davidjacobs21's Avatar
    i cant get any of that to work. its not the sensors arent on my phone
    05-01-2013 08:51 AM
  4. warpdrive's Avatar
    Did you guys turn on the features in the sub menu?
    sent with my 2 year old HTC evo3d
    05-01-2013 08:57 AM
  5. perrochingon's Avatar
    Yeah. I even did a few restarts and toggled them on and off several times to see if that fixed it but I didn't have any luck
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    05-01-2013 09:04 AM
  6. tohio's Avatar
    Does the Air Gesture icon appear in the top bar? It should be there when you are on a screen that accepts air gestures. I find in the browser I need to swipe down from the notification bar area towards the bottom of the screen to change pages.
    05-01-2013 09:26 AM
  7. madlaw1071's Avatar
    The gestures seem to work best in florescent lighting like in an office. I have a much higher success rate at work than at home.
    05-01-2013 09:50 AM
  8. perrochingon's Avatar
    Ok so air gestures works in browser. I was under the assumption that air gestures worked when someone called as well though. Maybe I'm wrong. I have yet to find an area on the phone where air view works.
    05-01-2013 09:54 AM
  9. tohio's Avatar
    Well there is Air Call-Accept. It is supposed to answer an incoming call when you wave your hand over the screen right to left. I just tried it and it works. Also, if there is a contact on the screen the phone will dial the contact when you place the phone to your ear. Just tried that as well and it works.
    05-01-2013 10:24 AM
  10. Eric Kane's Avatar
    For waking the phone and answering calls, swiping your hand over the Samsung logo while the device is laying on a flat surface seems to be necessary. As far as the browser/gallery are concerned, it can be used while in the hand. Your hand should be only a few inches above the sensor when swiping. Out of all the "gimmicky" features, Air Gesture is easily my favorite and I find myself using it often to wake my phone up and scroll through the gallery.
    Air View can be used to preview messages more than one line in length in the messages application. It can be used on Flipboard, on the stock video player, on the calendar (while in the application, not on the widget), and in the gallery as a preview of all the photos under a certain album.
    05-01-2013 10:26 AM
  11. perrochingon's Avatar
    So how do I put this..... Ok so I did not realize there is settings located within the settings with more settings within those settings for this stuff. I just got them working. Sorry guys. Total fail lol.
    05-01-2013 11:08 AM
  12. Eric Kane's Avatar
    Ha. Well at least now you can get these things to work.
    05-01-2013 11:12 AM
  13. warpdrive's Avatar
    Like I said, did u turn on the features in the sub menu....lol
    I'm glad you found it and it works for you now.
    05-01-2013 11:18 AM
  14. tohio's Avatar
    OK, you get my vote for the most honest poster on this Forum. Thanks.
    05-01-2013 03:24 PM
  15. Fahzan Mohammad's Avatar
    Mine still doesn't work even though I have my all setting on, it was working in trial mode only n in gallery. It doesn't in email or in browser. Also my air hover doesn't work I can't see the email unless I tap on it.
    05-12-2013 09:22 AM
  16. Machy0926's Avatar
    I've just bought GS4 since yesterday and I found an odd problem...
    When I enable the air gestures for example air jump, air move etc. none of them works.
    but when I try the training section they work correctly...
    even It's icon doesn't appear on the status bar, but it appears when Im trying the tutorial... and It just disappears when i go back to the menu..
    Need your help on this guys..thanks!
    06-08-2013 10:37 AM
  17. felloffthetruck's Avatar
    Don't worry, it's just another useless gimmick of the Galaxy S4. I played with them for about 5 minutes when I first received my phone and have not used them since.
    Topgonzo likes this.
    06-08-2013 10:43 AM
  18. GS4Bob's Avatar
    You must use the Samsung apps..ie IE for browser; "mail" for mail , etcin order for the air gestures to work.
    32GB GS4 via Android Central App
    06-08-2013 03:01 PM
  19. n4uau's Avatar
    You must use the Samsung apps..ie IE for browser; "mail" for mail , etcin order for the air gestures to work. 32GB GS4 via Android Central App
    I tried the screen shot and it worked once out of 50 tries. I should think this should work with all apps. I think it just a gimmick but the layout of the power button opposite the volume button makes the alternative method a bit iffy at times too. On iphone power button was on top and never had problem. Maybe with time I'll get used to this. For the camera however voice activation works great with 'cheese'.
    06-17-2013 06:00 AM
  20. Elijah Alvarado's Avatar
    I thought my air gestures weren't working either, the whole time I was using the Google Chrome app instead of the Internet app. The air gestures DON'T work on the Chrome app but it does work on the Internet app.
    06-18-2013 06:41 PM
  21. Nguyenning's Avatar
    Even when I use default apps, the little hand notification shows up in my menu bar but when I actually do the hand motions, nothing happens.
    Driving me absolutely insane
    06-28-2013 01:16 AM
  22. truthteller10's Avatar
    Sorry pal..but being a GN2 owner all that stuff they advertise JUST DOES NOT WORK..Its a hoax and a load of half baked so called features that make the phone a lagfest and sluggish to boot. Better learn next time to get a phone that has a greater focus on software improvements instead of gimmicks.
    06-28-2013 03:08 AM
  23. Kclove17's Avatar
    Hi! I just got my Samsung S4 today and I have been looking forward to using air gestures. But even if I enabled the air gestures app in the setting and in the sub menu it still won't work. I read online that there should be a light that turns on but the light hasn't turned on even though it said that it has been enabled. Can anyone guide me through this whole process?or tell what I'm doing wrong. I tried using the 'Help app' and when they do the tutorials it works but other than that, it doesn't work on its own.
    08-10-2013 01:35 AM
  24. Faloogs's Avatar
    Sorry for all of your issues. The sensor on the first phone I received was not working therefore none of associated functions did either. So within 24 hrs of receiving the phone I called Verizon tech support and they had me go through a bunch of things including a factory reset...the sensor still didn't work. So they classified the phone as DOA and I was able to go to the Verizon store and trade the broken phone for a brand new unit not a refurbished one. The sensor and all associated functions are now working as advertised and I'm loving this phone!
    Posted via Android Central App on my awesome Samsung Galaxy s4
    08-10-2013 05:18 AM
  25. llfloyd79's Avatar
    Under Air View in Settings, make sure Information Preview is on. I thought mine was not working either but once I turned it on I was good.
    Hope that helps. ...
    08-10-2013 06:14 AM
28 12
  1. flashplayer dont work in my tablet i10 android
    By abartolomey in forum New to the Forums? Introduce Yourself Here!
    Last Post: 01-15-2012, 07:36 AM
  2. updated my USB Drivers now roms dont work
    By Skrinkle in forum T-Mobile G2x
    Last Post: 08-27-2011, 01:29 AM
  3. Replies: 2
    Last Post: 08-03-2010, 02:26 PM
  4. Do those find my phone apps really work?
    By cmax in forum Android Apps
    Last Post: 07-31-2010, 04:53 PM
  5. google maps my location isn't working
    By jrappy87 in forum Motorola Droid
    Last Post: 05-10-2010, 05:14 PM
