1. AlphaVictor87's Avatar
    So i've never had problems connecting to my wifi here at work. When i got in today to set up the password, i didn't see it so i was trying to set it up with the WPA2 option, then all of a sudden i saw the network with full signal strength. I attempted to put in my username and password, but then it just disappeared. Since then its said "Not in Range" but i know where i normally sit i had always had full signal strength on my iPhone.
    Any ideas on how i need to get my S4 to be able to grab this again so i can connect? I've hit scan many times but it just still says not in range.
    05-02-2013 08:39 AM
  2. fatboy97's Avatar
    Check with other people to see if they can actually connect to that wifi router. The router might actually not be working correctly.
    05-02-2013 08:58 AM
  3. AlphaVictor87's Avatar
    Thanks fatboy i did check with others and they said it was working fine.
    Turns out even though its set up under wpa2 on my laptop, i had to use the 802.1x EAP not wpa2 and that let me type in the name of the network, username, and password. I guess they have the network setup to not be "findable". Once i typed that all in i connected in about 2 seconds.
    05-02-2013 09:14 AM
  1. 3G/4G not working but wifi is
    By 9878 in forum Sprint Photon
    Last Post: 04-25-2018, 08:14 AM
  2. Missing calls when WiFi is on...
    By waknowle in forum Verizon Galaxy S III
    Last Post: 01-08-2013, 03:10 PM
  3. Work Calendar is missing on LG Spectrum
    By conni52 in forum LG Spectrum
    Last Post: 06-26-2012, 06:12 PM
  4. Wifi Tethering missing from my Froyo
    By Vampy in forum Motorola Droid
    Last Post: 06-21-2010, 05:23 PM
  5. Replies: 0
    Last Post: 12-10-2009, 08:49 AM
