1. Michael Fullerton's Avatar
    Hi everyone,
    My new GS4 should be here tomorrow but I wanted to ask in advance regarding a spare battery.
    I have looked around but can only seem to find batteries for the I9500 version. As I'm in the UK I'll be getting the I9505 version.
    Also, I'm getting the Neo Hybrid case so a "larger" battery won't fit.
    Can anyone recommend a battery from a UK source at all please?
    Regards,
    Michael.
    05-02-2013 11:32 AM
  2. speed13's Avatar
    Also if you could share USA store as well.
    Sent from my Galaxy S4 White - using Tapatalk
    05-02-2013 11:38 AM
  3. AlphaVictor87's Avatar
    If anyone here in this thread also has any clue, i always like to have a spare charger at work. I don't want to order one from samsung, so does anyone know a cable from Amazon that is good and cheap that i could use as a work charger (don't need the wall plug, just usb to micro usb)
    05-02-2013 11:57 AM
  4. smooth4lyfe's Avatar
    Doesn't the battery for the 19500 also work for the 19505? I'm sure u can get any battery or wall charger compatible for the phone and it should work fine
    Sent from my Samsung Galaxy S3 Boyyyyyy!
    05-02-2013 11:59 AM
  5. LynnL's Avatar
    I'm not sure if this is what you need, OP, but Anker has a 2600 mAh available for the S4 (here it is at Amazon UK). It's compatible with Anker's multipurpose charger, which I bought with an HTC battery a few years ago. It's light and easy to tuck in a bag. I've had great luck with their batteries, and they're fairly inexpensive.
    05-02-2013 12:21 PM
  6. speed13's Avatar
    Any compatability usb cable would work fine. You can find one for few bucks at eBay or Amazon or some local store near you.
    AlphaVictor87 likes this.
    05-02-2013 12:33 PM
  7. Michael Fullerton's Avatar
    LynnL - That is just what I am looking for! Thank you!
    LynnL likes this.
    05-02-2013 12:52 PM
  1. Spare Battery Cases?
    By Prkl8r in forum EVO Accessories
    Last Post: 05-29-2010, 08:30 PM
  2. Spare battery charger?
    By Devobail in forum EVO Accessories
    Last Post: 05-22-2010, 06:45 PM
  3. Spare battery for the Droid?
    By fludkilla in forum Motorola Droid
    Last Post: 04-29-2010, 10:57 AM
  4. Google adds spare battery to order sheet...
    By LCW in forum Google / HTC Nexus One
    Last Post: 03-17-2010, 02:06 PM
  5. Is There a Spare Battery Charger for The Moment?
    By jb4kats in forum Samsung Moment
    Last Post: 03-10-2010, 10:23 AM
