1. oshogg's Avatar
    Subject says it all.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    05-03-2013 01:30 AM
  2. crester's Avatar
    Is it that poor?
    05-03-2013 01:31 AM
  3. Aquila's Avatar
    One could assume .75 to 2.25 hours of screen-on time and very little interaction with the device from this chart, but this one by itself doesn't show anything definitive. It doesn't include how much or how often wifi, mobile data, screen, etc are in use, how many times (if any) and how long it was charged since the timer began (that timer represents the last time it was at 100% charge), etc. If you tap on the chart, you'll get more comprehensive information. Based on what one can assume from looking at this, you're getting reasonable to slightly below average battery life for a modern phone, but where on that spectrum you specifically are depends a lot on the other information.
    05-03-2013 01:35 AM
  4. oshogg's Avatar
    Is it that poor?
    It is considering I used the phone very little at all during the day. Also, I don't know why "Google Services" and "Media Server" are using so much battery - I am not serving any media from my phone or using any of the google services explicitly. Is there a way to find out which app is ending up causing these 2 heavy battery usage items showing up at the top?
    Thanks,
    Osho
    05-03-2013 01:58 AM
  5. Aquila's Avatar
    Thanks,
    Osho
    Check to make sure "Currents" auto sync is set to off in it's settings.
    05-03-2013 02:02 AM
  6. oshogg's Avatar
    Here is another screenshot. As one can see, the phone died and I charged it a little and am using it again.
    I was on wi-fi most of the time btw.
    Aquila likes this.
    05-03-2013 02:05 AM
  7. oshogg's Avatar
    By "currents" - do you mean the "google currents" app ? If so, I don't have that app installed.
    There must be some other app that is keeping the phone awake a lot - which is being represented by the "google services" and "media server" - just can't figure out which app(s) it is.
    Osho
    05-03-2013 02:07 AM
  8. Aquila's Avatar
    Osho
    Yes, that's the one I meant... I know it has issues with Jelly Bean for some reason. Other than that, I think your best bet, with your device being so new, is either going to be the Note 2 and S3 forums or finding someone much more knowledgeable about TouchWiz than I am. I agree something appears wrong and it looks very similar to wake-lock issues experienced on the Note 2.
    05-03-2013 02:11 AM
  9. Rashawn29's Avatar
    download GSam battery monitor to find what's using your battery and keeping it awake
    Aquila likes this.
    05-03-2013 10:29 AM
  10. Almeuit's Avatar
    http://img.tapatalk.com/d/13/05/03/umupa7eq.jpg
    You have something waking up tour phone a ton... It has to be a app you installed that is doing alot in the background.
    Do this.
    Sent from my Sprint S3 using AC forums.
    05-03-2013 11:09 AM
  11. radiocaf's Avatar
    I also have this problem, although no where near as bad as you. Before, I also had Maps rather than Google Services using up most of my battery, now I have managed to quash that by turning GPS off (that easy... Go figure?) but this "Mediaserver" just won't move. I saw that Google Play Music was popping up in the RAM several times, and I have never used that app, so I disabled it, yet it's still there, although not as bad, but still something worth concern. I really want to know why mediaserver is still draining a fair amount of my battery. I don't have an SD Card installed, my theory is the GS4 is constantly checking for one, and that is draining battery through mediaserver, or it's an app, but I don't have any streaming apps other than YouTube, which I have used once and not seen pop up at all since.
    06-15-2013 10:14 AM
  1. Really Poor Battery Life?
    By sixstorm in forum Motorola Devour
    Last Post: 10-06-2010, 11:30 AM
  2. Is this normal battery life ?
    By OrderedtheEvo in forum HTC EVO 4G
    Last Post: 07-08-2010, 08:04 PM
  3. CAn someone please explain this to me?
    By joek1971 in forum The Android Central Lounge
    Last Post: 06-28-2010, 06:24 PM
  4. If you have poor battery life try this!
    By Gekko in forum HTC EVO 4G
    Last Post: 06-08-2010, 04:58 PM
  5. Can someone explain this?
    By sandplama in forum Google / HTC Nexus One
    Last Post: 05-27-2010, 09:18 PM
