11-09-2013 12:33 PM
124 1234 ...
tools
  1. thehatguy's Avatar
    Statusnone,
    That is correct. The Neo-Hybrid will not work with the Universal dock.
    The naked S4, the S-View and the $10.00 Spigen case are fine.
    John
    05-04-2013 04:37 PM
  2. GrooveRite's Avatar
    From the back and sides, it kind of looks like an iphone. Nice case otherwise.
    05-04-2013 04:57 PM
  3. jokout1's Avatar
    ordered mine in red Wed. May1 from Amazon, says it ships May 15...got confirmation email.
    Love the idea of the 2 piece design with no added bulk and like the look! Not worried about the dock since I'm planning on going wireless charging instead!
    Cheers
    05-04-2013 05:19 PM
  4. Wilbur's Avatar
    So I bit the bullet and bought the Spigen neo hybrid case sight unseen from Amazon Prime (love my free shipping). I was looking for a case that didn't add that much bulk to my phone, provided some protection, and still kept a good look for the device. In the past, I have always preferred to use my phone naked, but something about the size of the S4 screamed "put a case on it". I have the White Frost S4. I received the case in two days and it was very well packaged. The case is in two parts, the protective rubber back and then the white outter ring/sealer.
    The fit, design, and feel of the case is amazing! It does everything I was hoping it did and looks better than I thought it would. I'm really glad that I went with the white on white configuration! I didn't and doubt I will use the "jellybean" home button covers, but they are nice to have with the case.
    Onto my one and only gripe....the cutout for the charging port at the bottom. It's cut to only accept the Samsung micro USB charger (the one with the rather flat had). This is an issue for me, because I have chargers all around me in my living/working situation (two in the bedroom, 2 in the living room, 1 in the kitchen, 1 at work, 1 in the car) and only 1 of them is Samsung. Therefore, I would have to take the case off to charge with the others. VERY ANNOYING.
    Other than that, great case. See the pictures and let me know if you have any questions.
    Could you measure the open space available for the USB cable in millimeters? From your picture it looks about 3 mm of space in either direction from the socket before hitting the case.
    05-04-2013 10:23 PM
  5. JAshworth03#AC's Avatar
    The red looks very sharp! If I would have gone with a black S4, it would have been easy to use different colors with, but I was ready for a white phone. Either way, I like it a lot! Good look.
    Received my red today.
    The Samsung USB cable fits fine. I had another one laying around and that one fit fine also!
    The only one that didn't fit is the Samsung dock that I ordered. Damn it!
    Needless to say I won't be keeping the Neo-Hybrid for that reason.
    Instead I'll stick with the S-View cover. It fits the dock well.
    Am going to eBay the Neo-Hybrid. Listed as SPIGEN Neo Hybrid Dante Red case for Samsung Galaxy S4
    John
    05-05-2013 08:55 AM
  6. JAshworth03#AC's Avatar
    i assume you are looking for depth?
    05-05-2013 08:56 AM
  7. thehatguy's Avatar
    Cheers
    I didn't think you could use an accessory case and still use wireless charging.
    John
    05-05-2013 08:59 AM
  8. thehatguy's Avatar
    I measured the opening on mine:
    11.9mm x 6.0mm
    John
    Wilbur likes this.
    05-05-2013 09:21 AM
  9. Wilbur's Avatar
    11.9mm x 6.0mm
    John
    Thanks. I'll need to pull out the Dremel tool and grind off 1 mm from the width (6.0) side. I ordered the Silver Satin Neo Hybrid case ... still waiting for it to arrive. AND for Verizon to offer my future 32Gb GS4.
    05-05-2013 01:39 PM
  10. thehatguy's Avatar
    As I showed in my pics above, no issues with any of the USB cables I tried.
    John
    05-05-2013 02:31 PM
  11. pventur1's Avatar
    I'm loving the look of this case, but was curious on how much bulk it adds. Can someone provide a picture of the phone side by side the case? I would like to see the thickness of the case compared to the phone.
    05-05-2013 09:11 PM
  12. jokout1's Avatar
    check out the Amazon page for the Neo, it has several pics there and if I remember right it has some of the phone and case.
    Cheers
    05-05-2013 09:19 PM
  13. speed13's Avatar
    We already posted pictures. You should start little looking or read topics.
    Sent from my Galaxy S4 White - using Tapatalk
    05-05-2013 09:59 PM
  14. Statusnone's Avatar
    Dammit. I just got my Samsung universal dock. My girlfriend and I can't sleep without the lightning bug thunderstorm app playing and this dock makes it so easy to pop it in and play through the speaker system we have set up. I might have to cancel my order (again) for this case because I doubt I want to be taking it off every night. Really wanted this to work with the dock too. =\
    Sent from my iPad Mini using Tapatalk
    roberts68 likes this.
    05-05-2013 10:02 PM
  15. wallstreet123456's Avatar
    Since the Neo Hybrid only seems able to accept the Samsung micro USB charger (the one with the rather flat head) is there anyplace we can buy this OEM cable?
    Thanks
    05-06-2013 09:01 AM
  16. varsityhacker's Avatar
    Do you and your GF also need a night light to sleep as well?
    05-06-2013 09:18 AM
  17. epik16's Avatar
    sounds help with sleep, light not so much
    05-06-2013 09:41 AM
  18. thehatguy's Avatar
    John
    Doesn't anybody read all the posts?
    Every USB cable I tried works with the Neo-Hybrid.
    Others posted the same findings.
    Here are pics... again.
    John
    Attached Thumbnails Spigen Neo Hybrid (Infinity White) Case Review-nh2.jpeg   Spigen Neo Hybrid (Infinity White) Case Review-nh3.jpg
    Wilbur likes this.
    05-06-2013 09:56 AM
  19. Statusnone's Avatar
    By girlfriend I meant the empty other half of the bed that I keep a pillow on just in case I ever convince a real woman to make sexy time with me without money or a rag soaked in chloroform.
    Sent from my SAMSUNG-SGH-I337
    Attached Thumbnails Spigen Neo Hybrid (Infinity White) Case Review-uploadfromtaptalk1367853117762.jpg
    05-06-2013 10:12 AM
  20. varsityhacker's Avatar
    Well if you are as handsome as your self portrait then you should have no problems with the ladies. Have you considered maybe you have bad breath..
    05-06-2013 10:27 AM
  21. maximus96's Avatar
    how is the grip? is the white (or red) frame slippery? thanks
    05-06-2013 10:32 AM
  22. Statusnone's Avatar
    I wish I was as good looking as Mr. Derp. If only...
    05-06-2013 11:44 AM
  23. speed13's Avatar
    Just got my neo hybrid
    Attached Thumbnails Spigen Neo Hybrid (Infinity White) Case Review-uploadfromtaptalk1367860372059.jpg   Spigen Neo Hybrid (Infinity White) Case Review-uploadfromtaptalk1367860383098.jpg   Spigen Neo Hybrid (Infinity White) Case Review-uploadfromtaptalk1367860393118.jpg   Spigen Neo Hybrid (Infinity White) Case Review-uploadfromtaptalk1367860405085.jpg
    mitsueks and Wilbur like this.
    05-06-2013 12:14 PM
  24. mitsueks's Avatar
    Nice! Ordered mine last night. Hope all of my Palme Pre cords fit, I have those everywhere. Nice a Sonata! My wife is pissed at me since I just bought the S4 (and case) and a Compass-Nav for my SE. I think I am done for the rest of the year.
    speed13 and beastobadness like this.
    05-06-2013 12:20 PM
  25. speed13's Avatar
    Hahaha better don't buy anything else
    I'm ok with new case but not really impressed but it's ok. Good eye on Sonata
    05-06-2013 12:33 PM
124 1234 ...
  1. Spigen Neo-Hybrid / Dante Red case shipped today
    By thehatguy in forum Samsung Galaxy S4
    Last Post: 05-01-2013, 10:25 PM
  2. Question about Spigen Neo Hybrid Cases
    By smooth4lyfe in forum Samsung Galaxy S4
    Last Post: 04-27-2013, 01:50 PM
  3. Spigen Neo-Hybrid delay email
    Last Post: 04-25-2013, 04:25 PM
  4. Replies: 0
    Last Post: 01-12-2013, 02:10 AM
  5. SGP Neo Hybrid Case Video Review (Silver)
    By BlackPrince310 in forum Verizon Galaxy Nexus Accessories
    Last Post: 03-08-2012, 06:17 PM
