1. Brad Atradraco's Avatar
    Hey guys,
    Had my s4 since last friday,
    though the battery life is great id like a bigger one to get a bit more fo a boost/let me have the brightness a bit higher.
    I found some larger mah capacities on ebay and obviously theyre not official,
    i just wanted to check if they are safe/if anyone else has got or used one.
    Will post links below of ones im looking at,
    thanks!
    Brad
    High capacity 3030 mAh battery X1 for Samsung Galaxy S4 i9500 -HBT X1 | eBay
    NEW REPLACEMENT HIGH QUALITY 2800mAH BATTERY FOR SAMSUNG GALAXY S4 S IV i9500 | eBay
    05-04-2013 07:53 PM
  2. meyerweb#CB's Avatar
    I've used various brands of cheap aftermarket batteries in other phones, and they've all been fine in terms of working safely.
    I wouldn't count on them actually offering higher capacity, though. In my experience, these inexpensive aftermarket batteries offer less capacity than the OEM batteries. I use them as backups, in case the OEM battery dies during the day.
    It's really very difficult to get significantly more capacity in a battery the same size as the OEM one. All these batteries use the same Lithium Ion chemistry. Without making the battery bigger, there's really no magic that lets the same chemistry deliver more power. If you really need an extended capacity battery, wait a while and there will be physically larger, truly high capacity batteries available.
    05-04-2013 08:43 PM
  3. Calidoc's Avatar
    Does anyone know where you can buy the Samsung spare battery kit? It's on their web site, but cannot actually be purchased there. Has anyone seen it for sale?
    05-04-2013 08:54 PM
  4. areyes163's Avatar
    Amazon sells them. Although it says ships ehen available $49.99
    Samsung Galaxy S4 Spare Battery Charger (2600mAh Battery Included)
    https://www.amazon.com/dp/B00BW0XZO0...cUvbUpU2757786
    05-04-2013 09:59 PM
  5. Calidoc's Avatar
    Amazon.com: Samsung Galaxy S4 Spare Battery Charger (2600mAh Battery Included): Cell Phones & Accessories
    Says "out of stock." I think they are just not released yet.
    05-04-2013 10:09 PM
  6. areyes163's Avatar
    Yeah. I haven't actually seen one for sale. Only pre sale. Doesn't mean they have and just sold out just I haven't seen them yet and I have been checking around a bit.
    05-04-2013 10:10 PM
  7. bowebrpq's Avatar
    05-04-2013 10:11 PM
  8. Brad Atradraco's Avatar
    fair enough then, ill try and find one with a physically bigger battery and new cover.
    thanks for the help
    05-05-2013 06:09 PM
  1. All about Incredible batteries (Replacements, Charging..ect)
    By crspy in forum Incredible Accessories
    Last Post: 02-05-2015, 10:32 AM
  2. Another battery life question
    By shooter1701 in forum HTC Hero
    Last Post: 05-17-2010, 01:24 AM
  3. Battery Life Question
    By jwilcox09 in forum HTC Hero
    Last Post: 03-21-2010, 10:39 AM
  4. battery door question
    By cheeta186 in forum Motorola Droid
    Last Post: 01-08-2010, 04:08 PM
  5. Battery Charging question
    By grifforama in forum HTC Hero
    Last Post: 12-15-2009, 08:55 AM
