1. iOS Refugee's Avatar
    New to Android and GS4. How can I add a widget to my lock screen?
    Regards
    Sent from my SAMSUNG-SGH-I337 using Android Central Forums
    05-05-2013 11:57 AM
  2. Golfdriver97's Avatar
    Regards
    Welcome to Android and the forums! Hope you are enjoying the device.
    Don't have an S4, I have an S3, but this should be the same. Settings>Lock Screen>Lock Screen Options>Shortcuts On. Should have 4 apps on by default, and you may have to delete at least one in order to set aps to the lockscreen. And I think the limit is 4 or 5.
    iOS Refugee likes this.
    05-05-2013 12:06 PM
  3. Eric Kane's Avatar
    Regards
    Under settings, go to the My Device tab and select Lock Screen. Make sure Multiple Widgets is checked. Lock your phone and go to the lock screen. Swipe your finger at the top of the screen above the clock to the right to move to another screen. Click the + button and add your widget there.
    Sent from my Samsung Galaxy S4
    05-05-2013 12:09 PM
  4. nata_panya's Avatar
    I think this is possible only if you use the "swipe" lock screen.
    If you any other lock screen methof (eg pattern), it is not possible to put apps or widgets or camera shortcut on the lock screen. The option to do so is blocked (cannot switch on apps, widgets or camera).
    I think it is to like this to prevent bypassing the lock screen security. One of the security "flaws/bugs" on iOS and Android.
    05-05-2013 12:18 PM
  5. iOS Refugee's Avatar
    That worked! Thanks everyone for your help.
    05-05-2013 01:23 PM
  1. Lock screen help needed.
    By monkeyluis in forum General Help and How To
    Last Post: 08-26-2012, 03:42 PM
  2. Lock screen help
    By JeezyCreezy in forum LG Optimus S
    Last Post: 11-28-2011, 05:49 PM
  3. Lock screen help requested...
    By weirdherald in forum Sprint Photon
    Last Post: 09-14-2011, 10:15 PM
  4. Alarm on Lock Screen Help
    By pittsm in forum AT&T Captivate
    Last Post: 02-09-2011, 08:05 AM
  5. lock screen help
    By syrguy1969 in forum Verizon Droid Incredible
    Last Post: 05-02-2010, 07:52 PM
