1. texasotts's Avatar
    I am wondering if anyone knows how to install new weather icons into my uccw clock application? For some reason they are not showing up as an option when wanting to change icons. I have messed with it for days. I have four different icon packs installed in the uccw folder and within that another folder named weather. Anyone able to help?
    Sent from my SAMSUNG-SGH-I337 using Android Central Forums
    05-05-2013 04:45 PM
  2. Amged Osman's Avatar
    I had the same issue for the past two days, but apparently it's a "folder permissions" i've created a folder called "Default" inside UltilateCCWidget in SDCard and all Icons worked again
    05-20-2013 11:21 AM
  3. itsmesnitchess's Avatar
    does not work either..
    07-14-2013 03:04 PM
  1. clock weather widget help
    By Wishbon7 in forum Wallpapers, Ringtones, and Themes
    Last Post: 06-06-2010, 11:56 AM
  2. Renaming icon help
    By crwmlw#IM in forum HTC Droid Eris
    Last Post: 05-19-2010, 06:54 PM
  3. Weather Widget Help
    By bojowaggie in forum Android Apps
    Last Post: 04-29-2010, 01:18 PM
  4. Theme/Icon help
    By Roberts.Tyler3289 in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 03-16-2010, 07:49 PM
  5. Multiple Message icon help?
    By Crue4 in forum Motorola Droid
    Last Post: 11-18-2009, 06:45 PM
