1. j0n_8's Avatar
    Hi,
    Anybody having problem with using car charger (3rd party) with their S4? I've just bought the S4 and I used my old HTC car charger but it did not charge up, instead it said "dock detected". So I thought my old HTC charger cannot be used as it had a micro USB adapter.
    I went out to buy another USB charger (output 5v 1A) and tried with a new cable and it again didn't charge the phone (no sound no nothing upon plug in). I went on to try my old HTC phone and it charged up. I tried my wife's iPhone and it works perfectly.
    I know the S4 is using 5v 2A charger, but at home using wall outlet I tried using my old HTC charger which is 5v 1A and it worked! So far it's just my S4 not charging in the car.
    The only thing I have not tried is using a Samsung car charger to try as I don't have one.
    Is there anything I should know about or anyone having the same problem?
    05-06-2013 02:44 AM
  2. j0n_8's Avatar
    Sorry thinking out loud here...
    Is there a difference in the type of USB cables?
    05-06-2013 04:26 AM
  3. ibcop's Avatar
    05-06-2013 04:58 AM
  1. Car charger plus audio out equal signal noise
    By surfacinglove in forum Verizon Droid Incredible
    Last Post: 09-15-2015, 01:17 PM
  2. Car charger
    By bertbear in forum HTC Droid Eris
    Last Post: 11-03-2010, 06:31 PM
  3. Verizon car charger problems
    By kev83202 in forum Verizon Droid Incredible
    Last Post: 05-12-2010, 09:41 PM
  4. Non OEM car charger caused overheating
    By vatsyk in forum Verizon Droid Incredible
    Last Post: 05-11-2010, 11:44 PM
  5. Will my Storm 2 car charger work??
    By Huffdaddy1982 in forum Verizon Droid Incredible
    Last Post: 05-11-2010, 10:34 PM
