It is true direction to find hardware solution.
One guy made this operation and has a success to solve sim-problem:
He made the connection between capacitor 933 and capacitor on the sim-slot (marked on the picture).
Then, he took the soldering station and he was soldering every pin of NFC-chip (marked as light-green on the picture) with flux.
And during few weeks sim-card works correctly.
There must be 1.8 or 3 volts on sim power-connector, so it must be 1.8 or 3 volts on capacitor connectors at the certain time. If there are 1.5 or 2.5 volts - sim falls.
At Monday I was made all this operations, except capasitors connection. There were two errors since monday. I think, I need to connect capacitors to take full effect.
Sorry for my bad English! I want to find good solution together.
