Save big + get 3 months free! Sign up for ExpressVPN today
05-09-2013 02:59 PM
27 12
tools
  1. benbar21's Avatar
    Hey,
    I have an S4 with Rogers, and my battery is horrible
    I'll have it locked for 10 minutes, and it'll go down 5 percent. Whenever in use it the battery goes down around 1 percent every 2 minutes, if not more, and even when I'm texting
    This happens even with all background tasks closed.
    Any advice?
    Sent from my SGH-I337M using Tapatalk 2
    05-07-2013 07:36 PM
  2. alex346's Avatar
    That's strange... I'm in rogers as well... It's 10:05pm right now and I unplugged my phone from its charger this morning before work at about 7:45 am... As of this moment my battery is at 32% remaining with moderate use today... Any chance your battery could be defective?
    Sent from my SGH-I337M using Android Central Forums
    05-07-2013 09:09 PM
  3. smooth4lyfe's Avatar
    05-07-2013 09:12 PM
  4. gabidavila's Avatar
    I am having some troubles also,
    I posted in this thread:
    http://forums.androidcentral.com/sam...ml#post2764835
    I am very new with this android stuff, and this is my first android.
    Just got the phone less than a week, and the first couple days I thought the battery was the same as my iPhone 4 regarding the duration x usage, but as I started installing some apps, like, facebook, viber, whatsapp and others, my battery over night was completely drained.
    So today I reseted the phone to factory settings, and disabled GPS, and all this cool new sensors, and left enabled only: wi-fi and data mobile, I did not installed any apps yet, just updated the ones already installed.
    So now I have 7h and 36min since I completed the charged and the battery is in 41%.
    I didnt listen to music today, nor took any pictures, I did made some calls, an average of 20 minutes all of them, and did minor browsing, not much activity at all at the phone.
    So this is What I want to know: is this normal? Or my phone is with a problem?
    Please have this in mind: go back to the store I bought is out of the question because I bought in a vacation to the US and I am not there anymore.
    Thanks.
    05-07-2013 09:58 PM
  5. benbar21's Avatar
    I was looking through settings and I had "force gpu rendering" enabled, which could very well explain why screen on time used so much battery
    I disabled sync, and am going to unplug my phone tonight, and see what battery it's at in the morning
    05-07-2013 10:43 PM
  6. roberts68's Avatar
    I am happy with my battery life.
    Lasted all day yesterday using gps, maps, phone, air gestures, Facebook, apps, and lots more.
    Sent from my amazing Samsung Galaxy S4... there is none better!
    Attached Thumbnails Battery being horrible-uploadfromtaptalk1368012323972.jpg
    05-08-2013 06:25 AM
  7. crester's Avatar
    OP... please post your battery screen... it will show what is using your battery.
    05-08-2013 06:31 AM
  8. benbar21's Avatar
    I will tonight, once the battery gets low again.
    I would for yesterday but I had to charge it mid day so the stats would be off, plus I'm not sure if you can check a previous day's battery?
    05-08-2013 06:48 AM
  9. blamchop's Avatar
    Same issue for me. went to bed with 88%, woke up with 68%. I disabled GPS will give it a test tonight.
    05-08-2013 11:45 AM
  10. smooth4lyfe's Avatar
    Turn of "Smart Stay", that feature constantly runs and it drains ur battery
    I turned mine off and noticing a good difference
    Only turn features on when ur using them
    05-08-2013 11:48 AM
  11. archer75's Avatar
    I've had really good battery life with my phone. Insanely good. However different apps can have a massive negative effect on battery life. Over the years i've just learned which apps to avoid.
    05-08-2013 12:10 PM
  12. Matt Ng's Avatar
    Sorry if I'm derailing the topic but I can't help but notice that everybody who posts a screen shot always does so when their phone is at around 3-7%. Isn't it best practice to keep the phone around 20% - 80% since that's what keeps Lithium Ion batteries the healthiest? Thanks!
    05-08-2013 12:10 PM
  13. gabidavila's Avatar
    This is my screen, 20% under a hour, this is a factory reset, no GPS or this cool sensor were enabled.
    05-08-2013 06:38 PM
  14. Calidoc's Avatar
    These shots are pointless without knowing the screen time.
    http://img.davila.blog.br/var/albums...g?m=1368056039
    Looks like mine. Sucks.
    05-08-2013 07:01 PM
  15. gabidavila's Avatar
    @Cadiloc are you thinking about changing/returning the phone?
    05-08-2013 07:13 PM
  16. Calidoc's Avatar
    I love the phone aside from poor battery life. I'm hoping it will improve. <fingers crossed>
    I do get tired of reading posts telling people to turn off settings (GPS, wifi, air view, etc). I have so much turned off at times I might as well have it in airplane mode. What's the point of the features if they make the phone unusable because of the battery?
    gabidavila and Ruchi Dholakia like this.
    05-08-2013 07:26 PM
  17. gabidavila's Avatar
    I am cheering just like you, but I dont have warranty support, cause I am outside of the US, I bought the extra battery on amazon, I am waiting them to deliver, and I am hoping that the battery is the problem, because if it is the phone, I am f$#@!
    05-08-2013 07:31 PM
  18. benbar21's Avatar
    Here's my battery stats:
    I charged it to a hundred, unplugged around 130am, and went to sleep. Woke up at 7ish and the phone was down to 96%.
    Phone was down to 5% by 7pm, so 12 hours, and I wouldn't say that I used it very much(don't think I had 3 hours of screen time, but I will try to time myself tomorrow, as it's more likely that I am wrong than the phone is)
    Also never used maps, so don't know why it used 7% of my battery!
    05-08-2013 08:23 PM
  19. Calidoc's Avatar
    http://s11.postimg.org/z5zchvpgj/201...8_19_07_04.png
    http://s7.postimg.org/ia05gj2uz/2013_05_08_19_07_13.png
    Three hours of screen time is absolutely terrible. My iPhone used to get nearly three times that as I recall. I NEVER had to even THINK about my battery with the iPhone.
    05-08-2013 08:47 PM
  20. Parafly's Avatar
    What are some of your worst offendors
    Sent from my Nexus 7 using Tapatalk HD
    05-08-2013 08:50 PM
  21. Parafly's Avatar
    My galaxy nexus gets 5 hours from full to dead, on my desk at work it will drop 40 % per hour
    05-08-2013 08:52 PM
  22. titohiggins's Avatar
    Gabi, I am in SP, moving from a Iphone and very disappointed with S4 battery, if I have to turn on / off every service all the time ... better off back to Iphone, after 3 days of cycling the battery it got better, I am also waiting for a spare battery with fingers crossed. Mine is Vivo and I fully doubt they would ever change the phone here on a suspicious of a hardware problem, the Samsung specialist at a Vivo store had no clues about the fine tunnning of a S4, sofrivel.
    Rgds and good luck to us...
    Tito
    05-08-2013 09:04 PM
  23. gabidavila's Avatar
    I would be very happy if my phone only dropped 7% when I sleep, it is more like 35%...
    05-08-2013 09:11 PM
  24. benbar21's Avatar
    I've never gotten that battery with an iPhone. However I agree, this is worse than the iPhone(I have faith that it'll get better)
    I have juice defender, so it doesn't constantly sync.
    I really don't get why this is so bad. It'll go down a percent after 2 minutes of using evernote.
    05-08-2013 09:24 PM
  25. blackmalcoda00's Avatar
    wait nvm lol
    05-08-2013 09:43 PM
27 12
  1. When should the battery be broken in?
    By Jaredshoes in forum Verizon Galaxy Nexus
    Last Post: 09-22-2012, 09:35 AM
  2. Should My Battery Be At 15% in 3 1/2 hours??
    By MarkSeven in forum Verizon HTC Rezound
    Last Post: 08-29-2012, 05:08 PM
  3. Video proof that this battery is HORRIBLE!
    By dguidry12 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 05-30-2012, 06:41 PM
  4. Most Battery Being Drained By Gallery?
    By brettnussb in forum Sprint Nexus S 4G
    Last Post: 06-20-2011, 11:43 AM
  5. Great battery life to being horrible the last few days?
    By tcr04 in forum Verizon HTC Thunderbolt
    Last Post: 05-20-2011, 01:23 PM
