1. Anthony Chan 1688's Avatar
    How can I disable the camera click sound when I snap photo. Its so annoying. I have tried looking into camera & phone settings but cannot find anything on this.
    Any advise on this will be great. Thks.
    05-08-2013 09:58 PM
  2. djeff2's Avatar
    If you have sprint they disabled the silent setting for the camera. Put your phone on vibrate or silent and that should silence the camera also.
    05-08-2013 10:02 PM
  3. smooth4lyfe's Avatar
    The only way I see is to put it on silent mode, or Turn the Sound toggle off in notifications
    05-08-2013 10:03 PM
  4. Paul627g's Avatar
    This is always the first request it seems on more new devices.
    1. The carrier allows the camera to be silenced from within the Camera app settings or by simply silencing the volume levels, notifications, etc.
    2. The carrier/region has removed the option of silencing the Camera click due to different areas of the world having laws prohibiting disabling the sound per privacy laws.
    3. As with the S3 it ended up most had to root their device to disable the function if the carrier/region removed it.
    05-08-2013 10:04 PM
  5. Newtoandroid99's Avatar
    If your on AT&T you can disable this in camera settings. Camera>menu>settings>hit the gear and scroll down and you see the shutter sound toggle. I turned mine off ASAP.
    05-08-2013 10:09 PM
  6. smooth4lyfe's Avatar
    The option isnt there in the Unlocked version...I would have thought it would be
    05-08-2013 10:17 PM
  7. brianphrack's Avatar
    The camera silence problem... I encountered and researched this myself, one of the reasons I left Sprint, one of the more minor reasons, but none the less.
    I frequent art gallery and symphonic events where this was a problem, silencing the phone was the fix, however I also attend political events/meetings where it is acceptable and more so necessary to receive calls, while at the same time unacceptable and a nuisance having the 'damn' camera shutter sound go off for every picture snapped.
    In brevity, short of rooting, AT&T was the solution.
    05-09-2013 12:24 AM
  8. Riboflavin's Avatar
    I downloaded the Camera ICS app on my S2 on Sprint. Iunno if it is compatible with the S4, but check it out. You can silence the shutter sound in that app.
    05-09-2013 12:57 AM
  9. kh4fun's Avatar
    ProCapture Free lets you disable the sound, however the free version limits the resolution to 3.2MP. The paid version says it allows higher resolution pictures. Camera ICS sounds good. Going to try it to see what resolutions it supports.
    Topgonzo likes this.
    05-09-2013 07:41 AM
  10. James McCormick's Avatar
    Install Enforced Stream Silencer, open the app and check box to disable camera shutter sound.
    It's worked for me on Motorola Photon and Galaxy S4 for Sprint. Phone does not need to be rooted or unlocked.
    Apk and source here:
    https://sites.google.com/site/enforcedstreamsilencer/
    06-26-2013 11:06 PM
  11. ihbsbA's Avatar
    This works great, love it - thx
    Sent from my Galaxy S4
    Formerly "Evo_Girl"
    06-27-2013 07:47 PM
  12. GK3K's Avatar
    Worked on my non-rooted S4. Thank you, James!
    brianphrack likes this.
    07-14-2013 10:53 PM
  13. sheepseaexplorer's Avatar
    Thank you for this! Worked on my non-rooted Verizon S4
    07-14-2013 11:33 PM
  14. ttpp's Avatar
    This app was removed from google play. Now what?
    07-26-2013 04:48 PM
  15. GK3K's Avatar
    This link still works for me: https://sites.google.com/site/enforcedstreamsilencer/
    07-26-2013 05:06 PM
  16. GK3K's Avatar
    EnforcedStreamSilencer.apk
    Attached just in case the link gets pulled from the above link.
    07-26-2013 05:42 PM
  17. speedfreakz's Avatar
    I got it off play store and it works great
    07-26-2013 11:39 PM
  18. Patrick Tyrus 121's Avatar
    Sprint is getting better at this.....
    The Kyocera Torque still has a shutter with the
    Enforced Stream Silencer & Camera ICS.
    Setting the phone/volume to silence does not help either.
    Also looking to fix the hooks for the Audio Sources Mic works (Ambient/speakerphone), but voice uplink, voice downlink, and whole conversation does not work either.
    08-02-2013 09:37 PM
  19. WretchedM3's Avatar
    Does anyone know anything about this app? I have much caution about installing random apps! I am sick of getting the stink eye from people at events like my sons play from the stupid loud crack of the shutter sound! How does this app work? How does JB+ silence it? It seems there is a few different methods but the TW camera app does have a lot of useful features. I am just wondering how they do it with no root?!
    08-02-2013 10:21 PM
  1. disable Camera sound
    By omarnova in forum LG Optimus S
    Last Post: 06-09-2014, 10:54 AM
  2. Disable camera shutter sound?
    By stephentheh in forum Optimus Elite Rooting, ROMs, and Hacks
    Last Post: 02-04-2013, 07:58 AM
  3. so still trying to disable camera sounds
    By hiero in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 11-20-2012, 09:27 AM
  4. Disable Camera shutter sound?
    By bjones521 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 11-30-2011, 11:03 PM
  5. disable camera shutter sound?
    By ufergus in forum Motorola Xoom
    Last Post: 04-27-2011, 04:22 PM
