The Hustleman
They are marketing it as having 8 cores being able to simultaneous run together
Posted via Android Central App using my Nexus 4
Where do they say that?
I want to see some marketing material where they say it runs all 8 simultaneously
And the iPhone excels at that.
Actually the iphone USED TO excel with the user experience, but Android has overtaken them.
Android is now the simpler operating system AND the most advanced.
On an iphone, without jailbreaking and voiding your warranty, you can't even add a time stamp to your texts and so many other basic features. You're limited in your experience.
Meanwhile with Android, you can simply pick the phone up and run with it out the box, it just works without any tinkering, but if you want to change something, then do it, you're free to do so.
Then you know you'll be able to do everything the iphone does and then some.
It's a reason iphone is stealing features from android - they know they are behind in product quality and market share
Sent from my SGH-T999 using Tapatalk 2
