1. steveh552's Avatar
    I'm really new to Tasker but I'm frustrated. I'm trying to set a profile that when my phone is plugged in, weather at home or in the car the pin code is not required but when I unplug it the code is. IV followed instructions on YouTube and it just doesn't work for me. If anyone has one made in the s4 that works please provide details or maybe your files.
    ______
    Sent from my mobile device
    05-09-2013 08:35 PM
  2. steveh552's Avatar
    I figured it out, been working at this for a couple of hours
    ______
    05-09-2013 09:18 PM
  3. fantom305's Avatar
    Would that be by tweaking the DAYDREAM setting ??
    05-09-2013 11:59 PM
  4. SpookDroid's Avatar
    Mind letting us know how you got it to work, in case someone else runs into the same issue?
    05-10-2013 12:03 AM
  5. steveh552's Avatar
    I had to download secure settings and turn off widget locker.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    05-10-2013 12:16 AM
  6. steveh552's Avatar
    Here I s my xml
    <TaskerData sr="" dvi="1" tv="4.0u1m">
    <Profile sr="prof35" ve="2">
    <cdate>1368147330502</cdate>
    <edate>1368148991713</edate>
    <id>35</id>
    <mid0>36</mid0>
    <mid1>40</mid1>
    <nme>Lock/unlock On Charge</nme>
    <State sr="con0">
    <code>10</code>
    <Int sr="arg0" val="0"/>
    </State>
    </Profile>
    <Task sr="task36">
    <cdate>1368147334301</cdate>
    <id>36</id>
    <pri>10</pri>
    <Action sr="act0" ve="3">
    <code>150</code>
    </Action>
    <Action sr="act1" ve="3">
    <code>11820</code>
    <Bundle sr="arg0">
    <Vals sr="val">
    <com.intangibleobject.securesettings.plugin.extra.BLURB>Keyguard Disabled/BG</com.intangibleobject.securesettings.plugin.extra.BLURB>
    <com.intangibleobject.securesettings.plugin.extra.BLURB-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.BLURB-type>
    <com.intangibleobject.securesettings.plugin.extra.ENABLED>false</com.intangibleobject.securesettings.plugin.extra.ENABLED>
    <com.intangibleobject.securesettings.plugin.extra.ENABLED-type>java.lang.Boolean</com.intangibleobject.securesettings.plugin.extra.ENABLED-type>
    <com.intangibleobject.securesettings.plugin.extra.RUN_IN_BG>true</com.intangibleobject.securesettings.plugin.extra.RUN_IN_BG>
    <com.intangibleobject.securesettings.plugin.extra.RUN_IN_BG-type>java.lang.Boolean</com.intangibleobject.securesettings.plugin.extra.RUN_IN_BG-type>
    <com.intangibleobject.securesettings.plugin.extra.SETTING>keyguard</com.intangibleobject.securesettings.plugin.extra.SETTING>
    <com.intangibleobject.securesettings.plugin.extra.SETTING-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.SETTING-type>
    <com.twofortyfouram.locale.intent.extra.BLURB>Keyguard Disabled/BG</com.twofortyfouram.locale.intent.extra.BLURB>
    <com.twofortyfouram.locale.intent.extra.BLURB-type>java.lang.String</com.twofortyfouram.locale.intent.extra.BLURB-type>
    <net.dinglisch.android.tasker.subbundled>true</net.dinglisch.android.tasker.subbundled>
    <net.dinglisch.android.tasker.subbundled-type>java.lang.Boolean</net.dinglisch.android.tasker.subbundled-type>
    </Vals>
    </Bundle>
    <Str sr="arg1" ve="3">com.intangibleobject.securesettings.plugin</Str>
    <Str sr="arg2" ve="3">Secure Settings</Str>
    </Action>
    <Action sr="act2" ve="3">
    <code>11820</code>
    <Bundle sr="arg0">
    <Vals sr="val">
    <com.intangibleobject.securesettings.plugin.extra.BLURB>Clear Password</com.intangibleobject.securesettings.plugin.extra.BLURB>
    <com.intangibleobject.securesettings.plugin.extra.SETTING>password_reset</com.intangibleobject.securesettings.plugin.extra.SETTING>
    <com.twofortyfouram.locale.intent.extra.BLURB>Clear Password</com.twofortyfouram.locale.intent.extra.BLURB>
    </Vals>
    </Bundle>
    </Action>
    </Task>
    <Task sr="task40">
    <cdate>1368148151976</cdate>
    <edate>1368148351678</edate>
    <id>40</id>
    <nme>Lock</nme>
    <pri>10</pri>
    <code>150</code>
    <Int sr="arg0" val="1"/>
    </Action>
    <code>11820</code>
    <Bundle sr="arg0">
    <Vals sr="val">
    <com.intangibleobject.securesettings.plugin.extra.BLURB>Keyguard Enabled</com.intangibleobject.securesettings.plugin.extra.BLURB>
    <com.intangibleobject.securesettings.plugin.extra.ENABLED>true</com.intangibleobject.securesettings.plugin.extra.ENABLED>
    <com.twofortyfouram.locale.intent.extra.BLURB>Keyguard Enabled</com.twofortyfouram.locale.intent.extra.BLURB>
    </Vals>
    </Bundle>
    </Action>
    <code>11820</code>
    <Bundle sr="arg0">
    <Vals sr="val">
    <com.intangibleobject.securesettings.plugin.extra.BLURB>Set Pin</com.intangibleobject.securesettings.plugin.extra.BLURB>
    <com.intangibleobject.securesettings.plugin.extra.NEW_PASSWORD>2FD6CC3A8F20F3446DDDD187B24A77CA</com.intangibleobject.securesettings.plugin.extra.NEW_PASSWORD>
    <com.intangibleobject.securesettings.plugin.extra.NEW_PASSWORD-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.NEW_PASSWORD-type>
    <com.intangibleobject.securesettings.plugin.extra.PASSWORD_TYPE>pin</com.intangibleobject.securesettings.plugin.extra.PASSWORD_TYPE>
    <com.intangibleobject.securesettings.plugin.extra.PASSWORD_TYPE-type>java.lang.String</com.intangibleobject.securesettings.plugin.extra.PASSWORD_TYPE-type>
    <com.twofortyfouram.locale.intent.extra.BLURB>Set Pin</com.twofortyfouram.locale.intent.extra.BLURB>
    </Vals>
    </Bundle>
    </Action>
    </Task>
    </TaskerData>
    05-10-2013 12:18 AM
  1. Issue refreshing mail/apps on S4
    By nick911sc in forum Samsung Galaxy S4
    Last Post: 07-30-2013, 08:21 PM
  2. Signal Issues on Droid
    By samdroid in forum Motorola Droid
    Last Post: 04-30-2010, 10:05 AM
  3. YouTube Issues on Nexus One
    By biggbrother2 in forum Google / HTC Nexus One
    Last Post: 03-26-2010, 03:12 PM
  4. Odd Gtalk issue on the N1
    By Jeremy in forum Android Apps
    Last Post: 02-05-2010, 10:22 AM
  5. Overclock fixes backlight issue on Droid 2.1
    By jeffnucci in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 02-04-2010, 05:02 AM
