1. coryh131's Avatar
    On my Note 2, the Navigation voice was awesome and relaxing but now Samsung put the creepy S-Voice on the Navigation of the S4. Is there anyway to change the voice or do I have to continue to take a cold shower after using creepy Navigation!
    If this is my biggest problem, I know I have a great phone!!!!
    sean8102 likes this.
    05-10-2013 09:40 AM
  2. smooth4lyfe's Avatar
    You can change the voice
    Settings -> My Device -> Language Input -> Voice Recognizer....Change to Google
    ALSO
    Click Text to Speech option...change to Google
    sean8102, James Wiler and Nedla like this.
    05-10-2013 10:59 AM
  3. coryh131's Avatar
    It was already set to Google, I think I'm stuck with creepster voice forever! Thanks for trying though Smooth.
    05-10-2013 04:37 PM
  4. smooth4lyfe's Avatar
    Switch it to Samsung then switch it back...my Navigation voice is the Google one and thats the one that speaks....I hate the Samsung one
    05-10-2013 04:50 PM
  5. Omer AlKhanchi's Avatar
    You need to change the text-to-speech option under language and input to Google as well. Worked for me
    07-22-2013 06:40 PM
  6. Memein's Avatar
    You have to restart the mobile to take effect...you cant just select and change...First I also had the same problem...but after restarting the mobile it took google voice which is awesome....Try it
    - - - Updated - - -
    You have to restart the mobile to take effect...you cant just select and change...First I also had the same problem...but after restarting the mobile it took google voice which is awesome....Try it...
    12-30-2013 05:20 AM
  1. Why does the battery die so fast?!
    By DanX47 in forum HTC One M7
    Last Post: 04-27-2013, 10:17 AM
  2. Why does the camera load so slowly?
    By patfactorx in forum Motorola Droid 3
    Last Post: 08-24-2011, 09:44 PM
  3. Why does the Droid Charge benchmark so poorly?
    By dslayton in forum Verizon Droid Charge
    Last Post: 06-04-2011, 09:47 PM
  4. Why does the Xoom Price seem so bad?
    By natehoch96 in forum Motorola Xoom
    Last Post: 03-22-2011, 09:55 PM
  5. Why does the Bluetooth suck?
    By leathernuts#WP in forum Verizon Droid Incredible
    Last Post: 06-04-2010, 11:42 AM
