1. Gerard Schaefer's Avatar
    ok, I just switched from iphone to s4 and im having some sound issues. When listening to music I would say its atleast 30 percent lower sounding then my any other phone ive ever had. Its so low its almost awful. I tried poweramp and that has not seemed to help, I tried multiple headsets no avail. Is it possible somethings wrong with the phone? I mean I can hear the music its just not loud period. Any help would be appreciated, thanks guys
    05-10-2013 07:30 PM
  2. fantom305's Avatar
    Have you check the sound settings ??? the different sounds under Adapt Sound ??
    05-10-2013 07:54 PM
  3. Gerard Schaefer's Avatar
    Seems slightly better, do you continue to try and tweak it with the test until satisfied?
    05-10-2013 08:03 PM
  4. fantom305's Avatar
    I would.....
    05-10-2013 08:33 PM
  5. Gerard Schaefer's Avatar
    when the adapt sound is enabled does it change the sound volumes during music play? sorry for all the questions just used to having volume louder from music playback. Love the phone just need to get the volume right
    05-10-2013 09:24 PM
  6. Lee Ling's Avatar
    the deaf ppl create android 4.2.2 not phone setting. nothing can solve by now
    05-11-2013 06:20 AM
  1. Attaching sound issue
    By iler19 in forum Motorola Droid
    Last Post: 03-17-2011, 04:10 AM
  2. Ringtone, notification sound issue
    By cmiquel in forum HTC Aria
    Last Post: 08-30-2010, 03:43 PM
  3. Sound issue - 2.2 update
    By cy8ercop in forum Motorola Droid
    Last Post: 08-21-2010, 12:28 AM
  4. Notification sound issue?
    By CoryBantic in forum HTC EVO 4G
    Last Post: 07-01-2010, 01:56 PM
  5. Slacker Radio: Sound issues
    By speed_phreak in forum Android Apps
    Last Post: 02-22-2010, 06:30 PM
