1. Amy Schwarz's Avatar
    Just got my phone yesterday and I noticed while home on Wi-Fi the 4g symbol would occasionally pop up and then disappear but only used like 4 megs of data so wasn't worried about it. This morning I installed the ATT update which could be a coincidence but want to mention. Today my 4g I'd on all the time even while connected to Wi-Fi and it's definitely using it because I have gone up to 107 megs of usage. The symbol shows its being used when I go into apps like Instagram. Wi-Fi is fully functional because if I turn mobile data off it uses it fine, but if I turn it off I can't get MMS. Anyone else having this?? It's really making me mad!!
    05-11-2013 01:57 PM
  2. return_0's Avatar
    Perhaps you should try a restart or factory reset. That's the solution to the vast majority of these types of problems.
    05-11-2013 02:25 PM
  3. 20blks's Avatar
    Mms messages use mobile data. That's why
    05-11-2013 02:30 PM
  4. SpookDroid's Avatar
    Like 20blks said, MMS uses mobile data, not WiFi... Also, make sure that your WiFi settings are set to always keep the WiFi connection alive; otherwise, when idle, your phone turns it off automatically, which would kick-in the 4G.
    05-11-2013 02:34 PM
  5. Amy Schwarz's Avatar
    I figured our what was using it. An app called ATT Messages. It used 130 megs!!! I disabled it and now it's back to minimal usage. I know MMS uses it but I hadn't sent any all day so knew something was wrong. This app wasn't doing that yesterday so I have to believe it happened when I updated?? But solved it so I will edit the title with that in case anyone else had it happen..
    05-11-2013 02:40 PM
  1. Replies: 0
    Last Post: 03-08-2013, 07:12 AM
  2. using entire wallpaper instead of cropping
    By bojackson in forum Sprint Epic 4G
    Last Post: 08-20-2011, 06:56 PM
  3. Using K-9 instead of Sense email
    By realitydigg in forum Verizon HTC Thunderbolt
    Last Post: 03-25-2011, 05:17 PM
  4. Replies: 7
    Last Post: 07-13-2010, 05:55 AM
  5. Replies: 0
    Last Post: 04-05-2010, 08:26 AM
