1. CharlieS4's Avatar
    Is using a Kindle Fire charger or IPAD Charger ok with S4?
    05-12-2013 12:05 AM
  2. bosshaug12's Avatar
    Is it OK? Im not 100% sure what the answer to that is. But, between those two choices you should choose the iPad charger. Apple over-engineers their chargers for safety. I used an iPad charger pretty much the entire time I had my S3 and never had an issue. Also used it for my iPhone 4 and Note 2. Never damaged a device and charged it really fast.
    05-12-2013 12:11 AM
  3. brianphrack's Avatar
    Check the output on the chargers. Volts (V) and amps (A).
    With any transformer, if the Volts and amps are equal or below your device input, you are safe. (Safe for the most part, depending on the quality of the transformer.)
    If they are below, charging the device may go slow or not at all.
    05-12-2013 12:12 AM
  4. scorpiodsu's Avatar
    I'm using as iPhone charger if it helps AHAHAHAHA
    Sent from my SAMSUNG-SGH-I337 using Android Central Forums
    05-12-2013 12:29 AM
  1. HP Touchpad or Kindle Fire
    By noonebutkev in forum HP Touchpad
    Last Post: 02-26-2012, 03:31 AM
  2. WTB - Evo View or Kindle Fire
    By ad.. in forum HTC EVO View 4G
    Last Post: 01-30-2012, 02:43 PM
  3. Nook Tablet or Kindle Fire?
    By Aaron C#AC in forum Barnes & Noble Nook
    Last Post: 12-21-2011, 05:30 PM
  4. Nook Tablet or Kindle Fire?
    By Aaron C#AC in forum Amazon Kindle Fire
    Last Post: 12-19-2011, 09:44 PM
  5. Rooted NOOK Color or Kindle Fire (rooted?)
    By MeLikeyRoot in forum Barnes & Noble Nook Color
    Last Post: 12-17-2011, 10:14 PM
