1. hannahe26's Avatar
    i can not for the life of me figure out how to uninstall or whatever it is you do for themes i got it and have no idea how to take it off. i went from an iphone to the galaxy s4 and im still trying to figure out the basics. let me tell you its very difficult.
    05-13-2013 09:48 PM
  2. SimonZed's Avatar
    Try settings, then more, then application manager, then make sure you are looking at downloaded apps, then click on the relevant app and you should be given the option to uninstall.
    Did that work?
    05-13-2013 10:01 PM
  3. hannahe26's Avatar
    Did that work?
    no there arent any downloaded apps that have to do with the themes... do you know of the Go SMS Pro keyboard app ? i downloaded that and i think the theme may be coming from there but i dont know what to do...
    05-13-2013 10:10 PM
  4. SimonZed's Avatar
    So which exact theme are you trying to delete?
    05-13-2013 11:48 PM
  5. texasotts's Avatar
    Is it the go sms keyboard you installed and want to remove? If so then click your menu key and click on settings. Then go into your application manager and delete the go keyboard and it will take the keyboard and theme for that keyboard away. Are you wanting a different keyboard?
    Sent from my SAMSUNG-SGH-I337 using Android Central Forums
    05-14-2013 12:37 AM
  6. Lorraine Edwards's Avatar
    Worked like a charm...settings>applications>applications manager - choose app and choose uninstall. I'll not put back that "Go Keyboard" again.
    08-11-2016 11:58 AM
  7. helderA2005's Avatar
    Hello !!
    I bought a huawei and it comes with pre-installed themes from the mobile operator.
    I ask the code for make the phone free for all operators and I already root my phone. However I can't get ride of that stupid them. Could you help me??
    09-12-2016 04:13 AM
  8. Joyce Malcolm's Avatar
    Anything more up to date than 2013 please. I h ave a galaxy S7 edge and
    Although the app would appear to have installed how do I uninstall It.
    03-16-2017 01:41 AM
  9. Parizi's Avatar
    Similar problem. Very anoying...
    How do I uninstall Samsung Infinity wallpaper on S8?
    Somehow, I set the Samsung Infinity wallpaper on my S8 (not sure how).
    Problem is I cannot take it off my lock-screen and home-screen because:
    - there is no Delete option in Samsung Themes, only apply
    - each time I apply a new wallpaper (from Samsung Themes or another wallpaper app), I see it once and then it gets automatically replaced (both in the home and lock screens) by the Samsung Infinity wallpaper as soon as I unlock the phone
    - I can't uninstall Samsung Themes
    In other words, Samsung Infinity wallpaper has taken over my home and lock screens.
    Help !
    09-08-2017 03:53 AM
  10. Joyce Warney's Avatar
    I need to delete my Christmas wallpaper
    12-26-2017 09:38 AM
  11. kingkenth10's Avatar
    I have downloaded themes or wallpaper and cm launcher and I can't delete them
    07-29-2018 01:03 AM
  1. How to kill or uninstall factory installed apps?
    By brianrook in forum Samsung Moment
    Last Post: 01-09-2016, 02:20 PM
  2. droid theme help
    By kingofny#IM in forum Motorola Droid
    Last Post: 06-10-2013, 07:37 AM
  3. phone flicker or autobrightness. please help
    By tbdbuckeyeitl in forum Motorola Droid X
    Last Post: 07-31-2010, 10:50 AM
  4. Uninstall apps Help
    By crwmlw#IM in forum HTC Droid Eris
    Last Post: 05-19-2010, 05:56 PM
  5. xHero-2.1-Theme Help
    By TreyDaPrince in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 02-17-2010, 11:09 AM
