12-08-2013 01:34 PM
27 12
tools
  1. danangdevils's Avatar
    Has anyone found this or am I being stupid? Apparently it turns off the Wifi automatically when you are out of range of your specified router?
    05-14-2013 03:55 AM
  2. gabbott's Avatar
    It's right at the top when you go into wifi settings.
    05-14-2013 04:25 AM
  3. garry1bowie's Avatar
    Hmm, I don't seem to have that setting under wi-fi?! Only the option to switch wi-fi on or off?!
    05-14-2013 04:52 AM
  4. SERBDVB's Avatar
    same here missing that option
    thx
    05-14-2013 06:14 AM
  5. gabbott's Avatar
    I'm on Sprint. Perhaps it's carrier specific?
    05-14-2013 06:15 AM
  6. danangdevils's Avatar
    I'm missing this option too, very odd! Anyone else experiencing this?
    05-14-2013 06:16 AM
  7. garry1bowie's Avatar
    I'm in the UK on an unlocked S4. Maybe it's country specific?
    05-14-2013 06:17 AM
  8. Statusnone's Avatar
    On AT&T here and do not have the option. I'm guessing this is because AT&T has its own POS "Smart Wifi" app pre-loaded as bloatware with our model and they want you to use their app.
    05-14-2013 07:20 AM
  9. danangdevils's Avatar
    garry1bowie I'm on an unlocked version here in the UK too. Is there anyone who can verify it's carrier specific and maybe only available in the US?
    05-14-2013 07:43 AM
  10. procol's Avatar
    No option like that either. I'm on Korea Telecom in Korea.
    05-14-2013 08:02 AM
  11. garry1bowie's Avatar
    This is very odd!!
    05-14-2013 08:28 AM
  12. jonathan2677's Avatar
    Yeah im on tmobile in the states and no such iption, inly wifi on and off
    Sent from my black mist s4
    05-14-2013 08:33 AM
  13. garry1bowie's Avatar
    Stuff it! I'm contacting Scotland Yard and the FBI to get their top men onto this!
    05-14-2013 08:38 AM
  14. cjones's Avatar
    I am on Sprint and on the top of the page that lists all my Wi-Fi connections is a Smart Mode button. I hit that and it brings me to the settings page that explains the Smart Mode.
    By the way- It turns my Wi-Fi on when I get home or to work but doesn't turn it off when I leave those areas. Wish it would do that too.
    05-14-2013 08:39 AM
  15. garry1bowie's Avatar
    Wonder if it only shows when you're actually on wifi??
    05-14-2013 08:50 AM
  16. jneusch's Avatar
    The guy at the AT&T store told me to disable that app first because it is junk, lol. There is a setting in wifi advanced "Check for Internet Service". This looks at your current wifi speed and if it's too slow it will disconnect you and let you use mobile data. I tried that setting last night and it works well. My wifi is slow in my upstairs bedroom because the router is in the basement.
    Newtoandroid99 likes this.
    05-14-2013 09:12 AM
  17. smooth4lyfe's Avatar
    Get this app called "Smart WiFi Toggler"... It does the same thing and works amazing
    Sent from my Galaxy S4 Exynos!
    garry1bowie likes this.
    05-14-2013 09:24 AM
  18. garry1bowie's Avatar
    Big chap....you ARE the man!!
    dorins likes this.
    05-14-2013 09:30 AM
  19. garry1bowie's Avatar
    This is what I love about Android, being a lover of Apple, there's always an app for something you're looking for!
    05-14-2013 09:33 AM
  20. planoman's Avatar
    That was the first of many apps I disabled.
    Sent from my SAMSUNG-SGH-I337
    05-14-2013 10:05 AM
  21. wavygravy's Avatar
    I have just got my S4 in the UK from o2 and I have this feature its not an app its one of the features in the notifications bit at the top when you swipe down...where your WIFI , Bluetooth etc settings are.
    05-14-2013 02:15 PM
  22. patelkedar91's Avatar
    I'm on Sprint and I DO have this option.
    Weird -- did you Sprint S4 owners also get an update recently?
    05-14-2013 02:24 PM
  23. garry1bowie's Avatar
    Hmm....not there for me sadly.
    05-15-2013 05:33 AM
  24. danangdevils's Avatar
    Smooth4lyfe thanks for the app recommendation! Wifi toggle is quality!
    05-15-2013 08:07 AM
  25. rushmore's Avatar
    It is probably a reverse logic app and turns Wi-Fi off and data on, regardless of location. They want people to bust them data caps
    05-15-2013 06:59 PM
27 12
  1. Wifi Sleep Mode
    By corpgator in forum Google Nexus 4
    Last Post: 03-19-2013, 02:02 AM
  2. WiFi direct mode
    By bill2reg in forum ASUS Transformer Pad Infinity 700
    Last Post: 02-27-2013, 04:39 PM
  3. wifi sleep mode
    By curley1441 in forum Verizon Fascinate
    Last Post: 04-18-2011, 01:26 PM
  4. WiFi Sleep mode
    By icebike in forum AT&T Captivate
    Last Post: 08-27-2010, 03:44 PM
  5. App Needed: Control Wifi, sound, airplane mode
    By baycruisers in forum Motorola Droid
    Last Post: 11-07-2009, 04:34 PM
