1. awb594's Avatar
    My phone is less than a week old and this morning after being plugged in all night the phone had a message saying "Charging Paused Battery Temperature Too Low." Anyone seen this yet or know a fix? It was in a room that was around 64 degrees all night. The battery was at 100% but I am worried this may become an issue.
    05-14-2013 08:47 AM
  2. Jaguarr40's Avatar
    Believe it or not a simple battery pull and reset of your phone might just cure this issue and then keep an eye on it for about week. I have never heard of this on your phone being an issue.
    05-14-2013 10:54 AM
  3. MadaKor's Avatar
    I just had the same happen to me. Phone was at the same temp all day. Went for a walk while listening to music on the phone and all of a sudden it told me that battery temp was too low for charging when it wasn't even plugged in. Now I can't even charge my phone as it always tells me that the batt temp is too low.
    Tried several restarts and battery pulls to no avail.
    07-03-2013 09:35 AM
  4. saintgalmier's Avatar
    So what did you end up doing Madakor? I am having the same problem but my phone wont even stay on for more than 5 minutes while connected a charger. I am pretty sure it is the phone itself that is damaged, not the battery. I also have no sound coming from the speakers: ringtone, music, etc. This is all a result from the phone being dropped in water. After drying it out and cleaning it out completely it started to work fine except no speaker sound and no longer being able to charge the battery. The "temperature too hot/cold" message started to appear more frequently.
    I am trying to repair this myself with replacement parts, any and all advice would be helpful.
    Thanks!
    07-10-2013 04:26 AM
  1. Battery charging issue after 2.2...who to notify?
    By Chondog in forum Verizon Droid Incredible
    Last Post: 09-08-2010, 01:00 PM
  2. Serious charging issues!!!
    By captainsplat in forum Sprint Epic 4G
    Last Post: 09-01-2010, 08:34 PM
  3. Charging Issue
    By as4life in forum HTC EVO 4G
    Last Post: 06-05-2010, 11:37 PM
  4. Charging Issue
    By Fazulka in forum HTC Hero
    Last Post: 05-16-2010, 08:41 PM
  5. charging issue?
    By johnolesen in forum Motorola Droid
    Last Post: 05-15-2010, 10:15 AM
