Son just got an S4. I am a little jealous. I thought I had read that the S4 was going to have Inductive charging to support both Qi and Powermat, but have not seen anything yet. Has anyone heard anything about this or know what is supported?
I agree for the most part but you're missing two items to think about. 1) convenience of just dropping it on a charger one handed and picking it back up to go or use. 2) I have worn out USB sockets phones before, total loss.Not yet, but coming... You'll need to buy a special backcover, though... In any case, why go Inductive? The charger is way too expensive, it is still attached to a power outlet or charging port, the phone still needs to be in contact with the cradle, and good luck if you want to use it comfortably while charging... I'd rather deal with a cable than with all that, IMHO
Only one I have seen so far:
WiQiQi for Galaxy S4
Nothing yet on Qi or Powermat brands that I know of. Based on the above link though, they will make ones that fit inside the stock battery door or replacement battery doors of the same stock size, without compromising the size of the phone.
It is an inefficient way to charge a phone (uses more electricity), and the hardware is much more expensive ($30 - $40 compared to a $10 plug-in).
That being said, it was one of the coolest things on my Palm Pre, and I had a Touchstone at my office, and another on the kitchen counter. Sign me up.
There's a $30 kit on ebay that puts an inductive film inside your existing phone, using your same back cover that let's you use your S4 with Palm touchstones. I have one in my car from my palm phones I used to have and one next to my bed.
http://item.mobileweb.ebay.com/viewitem?itemId=121105143897&index=0&nav=SEARCH&nid=73710582913
Check it out!
https://www.youtube.com/watch?v=l8nqXYii9OM&feature=youtube_gdata_player
Sent from my AT&T Samsung Galaxy S4 using Tapatalk 2
Is touchstone compatible with qi?
Sent from my Nexus 7 using Tapatalk HD
Check it out!
Does this work with a case, such as a Ballastic?
I emailed the seller earlier this evening to ask. Cause I have an incipio dual pro shine on mine.
https://forums.androidcentral.com/e...2Fsamsung-galaxy-s4-cases.html&token=1UNaAw7l
No, I do not believe touchstone and Qi are not compatible.
