1. Ameer Nuub's Avatar
    One of the big things about the S4 and droid is the customization available vs. iphone.
    In Windows, you can customize each system sound for each event to whatever sound file you like. I see there is the ability to do this for a very limited number of system sounds for the S4, but not much.
    Is there a method I missed or an app available to allow me to customize all or most of the system sounds?
    Thanks!
    05-15-2013 10:22 AM
  2. Mojeans's Avatar
    Can't help but I have a very similar question.... I can't seem to turn off the audio notification for my ActiveSync emails. Active Sync --> Menu --> General Settings has a listing for "priority sender" sounds but I don't see it for normal emails. Thought I'd keep it in the same thread!
    05-15-2013 01:08 PM
  1. Bluetooth problems = System sounds low after using
    By Addie_Goodvibes in forum Sprint Epic 4G
    Last Post: 09-17-2012, 10:10 AM
  2. iPhone System Sound Files
    By OutGolfn#AC in forum Wallpapers, Ringtones, and Themes
    Last Post: 06-25-2011, 08:50 AM
  3. System Sounds through Bluetooth
    By csyrell in forum AT&T ATRIX
    Last Post: 02-22-2011, 01:40 PM
  4. help with custom boot sound
    By midnight93933 in forum Verizon Fascinate
    Last Post: 02-06-2011, 07:33 PM
  5. How to disable system sounds while chargin!?
    By ywenz in forum Sprint Epic 4G
    Last Post: 09-16-2010, 11:59 AM
