1. Ashiki's Avatar
    This is my second Android phone, my first being an Inspire. I love the G4 but have a few questions. With my Inspire I could use a usb cable and then access files off of it but if I try with the G4 I can see the files but then it will say 'MTP application will restart to prepare SD card. Continue?'. If I click ok it just goes through the cycle again. I also seemed to have some trouble syncing it with Kies. Is there a setting or something I should check?
    Also, I have a purple led light that I can not figure out what it is. Has anyone else had that problem? I thought it was from AT&T Messages and I *think* that might be it but even after going through any unread messages there it still sometimes blink. I need to uninstall it to see if it disappears.
    Last question, has anyone had any problems with LightFlow resetting their notification sounds? I had it set up and after resetting my custom tones multiple times I believe it was Lightflow so am only using it for ones that are necessary and I have not had any additional problems.
    Thanks in advance!
    05-15-2013 12:33 PM
  2. TCaRRtel's Avatar
    Okay first off is the files. I use an application on the computer called Android File Transfer. Use that and your file problem will be taken care of. Next, I am unsure of the purple LED. I have a Sprint S4 and do not have this problem. Lastly as far as LightFlow goes, I have not had any problems.
    05-16-2013 09:53 PM
  1. Faster way to mount as USB drive?
    By youngjediboy in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 06-28-2012, 10:17 AM
  2. Replies: 20
    Last Post: 06-21-2012, 10:45 AM
  3. see phone as usb drive on PC
    By terryt737 in forum Samsung Galaxy S II Skyrocket
    Last Post: 01-05-2012, 08:19 PM
  4. Can't use Tbolt as USB drive for PS3
    By jpattersonlee in forum Verizon HTC Thunderbolt
    Last Post: 04-18-2011, 08:44 PM
  5. Relative Rookie...Few Questions re: blank screen & contacts
    By eric0668 in forum T-Mobile Vibrant
    Last Post: 08-10-2010, 04:07 PM
