1. ChiribaoGA's Avatar
    Does anyone else's Neo Hybrid have this dent on top of the hole for the Micro USB port? Is this one defective or is this how they are made?
    P.S. I have already verified it is authentic.
    Attached Thumbnails Spigen Neo Hybrid: Flaw or Design?-dsc05878.jpg
    05-15-2013 05:53 PM
  2. TheLegoman's Avatar
    It looks like that case is defective. I have seen pictures of this case, and none of them have that defect. I would definitely get it replaced.
    05-15-2013 06:00 PM
  3. JawjaBill's Avatar
    Ditto Legoman. I have the silver one and it is definitely not bent.
    05-15-2013 06:11 PM
  4. ChiribaoGA's Avatar
    Ok. I'll definitely do that. Thanks!
    05-15-2013 06:13 PM
  5. thehatguy's Avatar
    Had the red one. No dent.
    John
    05-15-2013 06:52 PM
  6. Tar Heel's Avatar
    I have the yellow. No dent. Sorry bud.
    05-15-2013 06:58 PM
  7. jpullins's Avatar
    Metal slate here no dent.... Send it back
    05-15-2013 08:45 PM
  8. speed13's Avatar
    I have white one and no damage
    Sent from my Galaxy S4 White - using Tapatalk
    05-15-2013 10:35 PM
  9. mballs4life's Avatar
    Mine is also white with no damage. Sperate issue though, do any of you have/use an auxiliary cable? I have a Belkin that won't reach because of the frame of the case. I emailed Spigen about it but no response yet.
    05-16-2013 12:55 AM
  10. DioramaMaker's Avatar
    I'd call that a defect for sure. Send it back, or heat it up and bend it into place, followed by prompt cooling.
    I don't have the Spigen Case, but I had the issue with my iPhone's Commuter case. I ended up getting this cable:
    And then this one to replace it when it got bent up too much.
    I DEFINITELY prefer the white one, as it has seemed tougher, and the grip on the plug is more comfortable to use. It also has a better rating on Amazon's reviews. But I can confirm they fit the Cmmmuter's "narrow" aux port, and I never had another cable that worked with the case because of said port's diameter. I'd assume you'd be safe with this one. Order it for sure, Best Buy's in-store price is pretty steep on the black one, and I don't know if they carry the white at all.
    mballs4life likes this.
    05-16-2013 01:54 AM
  11. mballs4life's Avatar
    http://ecx.images-amazon.com/images/...tL._SY300_.jpg
    http://ecx.images-amazon.com/images/...qL._SX300_.jpg
    I'll definitely check that white one out. Thanks!
    Posted from my Galaxy S4 via Android Central App
    DioramaMaker likes this.
    05-16-2013 09:13 AM
  12. DioramaMaker's Avatar
    No problem, glad to be of help.
    05-16-2013 10:54 PM
  1. Spigen Neo Hybrid (Infinity White) Case Review
    By JAshworth03#AC in forum Samsung Galaxy S4
    Last Post: 11-09-2013, 12:33 PM
  2. Spigen Neo-Hybrid / Dante Red case shipped today
    By thehatguy in forum Samsung Galaxy S4
    Last Post: 05-01-2013, 10:25 PM
  3. Question about Spigen Neo Hybrid Cases
    By smooth4lyfe in forum Samsung Galaxy S4
    Last Post: 04-27-2013, 01:50 PM
  4. Spigen Neo-Hybrid delay email
    Last Post: 04-25-2013, 04:25 PM
  5. Replies: 0
    Last Post: 01-12-2013, 02:10 AM
