1. Ameer Nuub's Avatar
    I like the Weather Widget for the Sprint S4, but it takes up WAY too much real estate. I would like it in 4x1. Is there a way to reduce this widget?
    I know there are a ton of weather widgets to choose from, and I would switch if it were the exact same, but smaller. I like / want the large time and date, the large temp, the graphical animation over the whole widget background that matches current conditions... I just want it 4x1.
    Thanks!
    05-16-2013 11:58 AM
  2. SpookDroid's Avatar
    They changed it from the version on the GS3 and Note 2 (I liked the icons better back then), but for some dumb reason, they also took out the ability to resize the widget (you could do it in the Note 2, at least). Your best bet is either to download another weather app (Beautiful Widgets has some nice ones) or switch launchers (I know GoLauncher allows you to resize ANY widget on your home screens, and I believe most of the good ones do, too).
    Ameer Nuub likes this.
    05-16-2013 12:03 PM
  3. MikeDubC's Avatar
    Beautiful widgets has some nice alternatives.
    05-16-2013 12:12 PM
  4. Ameer Nuub's Avatar
    Great info, thanks!
    05-16-2013 01:14 PM
  5. scorpiodsu's Avatar
    As above, maybe use another widget or try a launcher that allows you to resize. Basic stuff like changing the grid size and resizing is always missing from these stock launchers. That's one of my gripes with Android..... they depend too much on 3rd party apps to fill in the gaps for some no-brainer functionality.
    05-16-2013 01:24 PM
  1. Lockscreen widgets - Any way to turn off the highlighting of the left side?
    By severinj in forum Google Nexus 7 Tablet (2012)
    Last Post: 08-22-2013, 02:39 PM
  2. need some help ! how to change weather widget from C to F
    By Sarah Cohen Glick in forum Samsung Galaxy S III Accessories
    Last Post: 05-28-2013, 05:28 PM
  3. ways to reduce usage of 3g
    By zachary.rafferty in forum Virgin Mobile Optimus V
    Last Post: 07-21-2011, 12:57 PM
  4. Replies: 2
    Last Post: 08-26-2010, 02:50 PM
  5. New to Sprint from AT&T - Best way to transfer contacts?
    By DisplacedMic in forum HTC EVO 4G
    Last Post: 06-09-2010, 10:17 AM
