1. shoii's Avatar
    Hey guys I'm fairly new at this and I just ordered my S4 and is set to arrive the day of a party of mine. Since I'm a bit of a show off (gonna be the first with an S4 with friends haha) I'd like to know if the initial battery is enough to get me through one night. Also if its not a good idea to do so or I should charge it initially for a long time. Thanks!
    05-17-2013 02:21 PM
  2. hobbsave's Avatar
    Battery comes about half charged 50% which should last 5-10 hours based in my experience.
    Sent from my SAMSUNG-SGH-I337 using Android Central Forums
    05-17-2013 03:30 PM
  3. Eric Kane's Avatar
    Typically when you first get a new phone, you'll be spending a good amount of time setting it up/playing with it. I'd advise to let it go through the initial setup (download your apps, etc) and then stick it on the charger it comes with. One of the beneifts of the S4 is that it has a 2 amp charger which means it can charge pretty quickly. If you can spare 30 minutes to an hour to charge it, you should have enough battery to last a night.
    05-17-2013 03:41 PM
  4. SpookDroid's Avatar
    It should for a couple of hours (let's face it, if you're gonna show it off you're gonna keep the screen on at all times, pressing and clicking and activating features and using them left and right... while in normal use 50% should even get you through a work day, it doesn't when you'll be pushing the phone to do everything ) In any case, remember that the best practice is to let your battery charge to 100%, let it discharge COMPLETELY until the phone shuts off on its own, and then re-charge to 100%. (NOTE: This is not to improve the battery, it actually doesn't give a rat's behind whether you charge it half-way or use 10%'s all the time, but the software needs to calibrate to accurately show your battery percentage)
    05-17-2013 03:41 PM
  5. shoii's Avatar
    This sounds interesting I might just try this, thanks!
    05-17-2013 04:42 PM
  6. shoii's Avatar
    Would like to get more takes on this.
    05-19-2013 08:44 PM
  7. thegrants82's Avatar
    Way way wrong.
    05-19-2013 09:45 PM
  8. shoii's Avatar
    Way way wrong.
    What's wrong?
    05-19-2013 10:17 PM
  1. Samsung Galaxy S4 Genuine Battery - dock home charger
    By speed13 in forum Samsung Galaxy S4
    Last Post: 05-27-2013, 08:56 AM
  2. Does the initial battery charge go slowly?
    By barskin in forum AT&T Galaxy Note 2
    Last Post: 11-28-2012, 03:55 AM
  3. Initial Battery Charge For Galaxy S2
    By mechanismclear in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-17-2011, 04:22 PM
  4. GS II Epic 4G Initialize Battery
    By elektro in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-06-2011, 11:49 PM
  5. Initial battery Charge? (I know, here we...)
    By JohnnyBeGood in forum HTC EVO 3D
    Last Post: 06-24-2011, 10:23 AM
