I had bought some for my Nexus 4 a while back from amazon and they work fine with the S4. Search NFC tag for Nexus 4 on Amazon and they should come up. The app I use to program them is NFC task launcher. Make sure the tags you get are compatible since there are two types. I believe they are the NTAG203 type.
