1. therussiann's Avatar
    i work with 99.8% pure oxygen and when i herd that this phone has a built in thermometer it was very interesting to me for work reasons.
    the question is has anyone found a way of using that sensor to tell the temp outside?
    05-17-2013 09:01 PM
  2. fieldegl's Avatar
    Read this article today.. You may find it interesting.
    How to Turn Your Samsung Galaxy S4 into a Personal Ambient Weather Station http://drippler.com/updates/share/ho...eather-station Via j.mp/getDrippler
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    roberts68 and Calidoc like this.
    05-17-2013 10:28 PM
  3. sox08's Avatar
    thanks for creating this thread. hopefully more apps will come forward to use these sensors. I already use beweather and mycast classic but I want actuals where I currently am and the app in your link looks pretty good. anyone know of any others?
    05-18-2013 11:18 PM
  4. Calidoc's Avatar
    I like having the thermometer, but it is really impacted by physical touch and takes a while to get a true reading. I also would like to see some accuracy tests.
    05-19-2013 05:21 AM
  5. dwhitman's Avatar
    I'm a lab chemist who takes measurements like these very seriously.
    The trouble with temperature sensors built INTO a device (as opposed to connnected to the outside somehow) is that the equilibration time can be pretty long. It's also problematic to put the sensor in an enclosure along with a heat source (CPU, battery during charging, etc). As such, I'd only count on the thermometer being accurate if it'd sat away from your body, in the environment you wanted to measure for a while, screen off and not being charged.
    Humidity sensing is notoriously difficult and slow even with lab-grade instruments that are periodically calibrated against salt-solution standards. I have very low expectations for the humidity sensor on the S4.
    Pressure is easier to sense than temp or humidity. I'm cautiously optimistic that we can get good real time data out of that one.
    05-19-2013 06:09 AM
  6. EMY92's Avatar
    The temp sensor isn't very accurate, I've let the phone sit overnight and the first action I took was to try the temp sensor, it was off by 15 degrees.
    05-19-2013 08:40 AM
  7. therussiann's Avatar
    yea its not accurate at all i suspect it is because of the case and the fact that its inside next to other components that get hot
    05-19-2013 10:02 AM
  1. Replies: 0
    Last Post: 09-22-2012, 01:27 PM
  2. Anyone use the built-in Tasks app?
    By Jaggrey in forum HTC EVO 4G LTE
    Last Post: 07-06-2012, 12:20 PM
  3. Length of videos using the built in camera
    By Charlesleonard in forum Acer Iconia A500
    Last Post: 09-01-2011, 05:18 PM
  4. Is the built-in Facebook..
    By sniffs in forum Motorola Droid
    Last Post: 04-26-2010, 10:38 PM
  5. Email (the built in app)
    By ScotterMonkey in forum Android Apps
    Last Post: 07-20-2009, 04:11 PM
