1. MrBrownstone's Avatar
    I followed the directions in the mini manual provided by the manufacturer but the feature where I can view one app over the other doesn't work.
    When I used YouTube on my previous device, I could dark the screen and the video would still play do that I could still hear audio. If I had that feature OR the ability to text or to access my EQ etc that would be all would need. Anyone know a solution?
    05-18-2013 12:43 PM
  2. SpookDroid's Avatar
    To activate multi-window the notification bar toggle for that feature MUST BE ON. To activate it long-press the back button until the multiwindow bar shows up. Just remember, not all apps are multi-window compatible, so you won't see all of them in there. The YouTube app IS compatible, but not if you are watching the video via browser.
    I can't recall in my SII, but on my Note 2 and the S4, if you're watching a YouTube video and you turn the screen off, the whole video (and therefore, audio) stops. I still haven't found an option to disable this.
    05-18-2013 12:48 PM
  3. MrBrownstone's Avatar
    Thanks. Still not working based upon your suggestion. Just in case, I thought I'd try twice, even factory data reset. No luck.
    Thanks anyway
    05-18-2013 06:15 PM
  4. ragamuffindianne's Avatar
    A million thank. I use multi-window a lot, but the tab often disappears, I love the long press of the back button !
    Sent from my SGH-M919 using Android Central Forums
    05-18-2013 09:13 PM
  5. Each3's Avatar
    Thanks anyway
    Are you dragging the icon to the screen to activate the multi screen?
    Get on the default Internet app then press the back button to bring up the list of compatible apps and then drag one to the screen and it should snap it
    05-18-2013 09:49 PM
  6. mufaddal.ezzi's Avatar
    I'm currently on 4.1.2 (official version) un rooted..my muti window crashes alot when using the apps sometimes it make me so angry because whenever it crashes all the apps I was in exits and force closes..anyone can help me fix this
    05-20-2013 07:10 PM
  7. fantom305's Avatar
    If you are on 4.1.2 you apparently don't own an S4....... may be you should try to find answers on the S3 forum ................
    05-20-2013 09:32 PM
  8. Kane David's Avatar
    if you want it work go to setting-home screen mode - then but it on standard mode
    11-11-2013 08:05 PM
  1. IS The GS3 ever getting the Multi window feature?
    By Biga173rd in forum Sprint Galaxy S III
    Last Post: 12-10-2012, 07:53 PM
  2. Multi Window Feature for the GS3 anyone??
    By Biga173rd in forum Samsung Galaxy SIII I9300
    Last Post: 10-16-2012, 12:52 PM
  3. Multi window feature from note 2
    By Nazty111 in forum Samsung Galaxy S3
    Last Post: 10-06-2012, 06:31 PM
  4. My GPS Feature Doesn't Work
    By SylvianDark in forum LG Optimus S
    Last Post: 11-11-2011, 01:27 AM
  5. Voice to text feature doesn't work sometimes
    By ashakouri1 in forum Android Apps
    Last Post: 11-24-2010, 02:45 AM
