Save big + get 3 months free! Sign up for ExpressVPN today
  1. smooth4lyfe's Avatar
    I have a 32GB SanDisk HC card and it seems to be the culprit of my battery drain! Anyone have any suggestions... I might switch to a different company card
    Sent from my Galaxy S4 Exynos!
    Attached Thumbnails Any way to prevent my SD Card from taking so much battery?-uploadfromtaptalk1369171886723.jpg   Any way to prevent my SD Card from taking so much battery?-uploadfromtaptalk1369171899106.jpg
    05-21-2013 04:31 PM
  2. Each3's Avatar
    I've heard if you reformat the card through the phone that it should fix the problem..
    Just make sure to back up everything in the SD card
    05-21-2013 04:57 PM
  3. scorpiodsu's Avatar
    That most likely means you have an app that is constantly reading your card or a corrupt file on it. Download wakelock detector and see if it can help pinpoint it for you. But like the previous user says many have to reformat their card to fix the issue.
    Here's a thread that may help you. I use greenify to deep sleep most apps to prevent them using power. But I've never had the media wake lock problem.
    http://forums.androidcentral.com/sam...g-battery.html
    Sent from my SAMSUNG-SGH-I337 using Android Central Forums
    05-21-2013 09:00 PM
  4. jneusch's Avatar
    This happened to me on my Note 2. It was a corrupt music file. Reformat the card using the format tool on the phone, then reinstall your music, etc. Your problem should be solved with that.
    05-21-2013 11:17 PM
  1. Any way to prevent soft keyboard from auto-popping up in sms?
    By krasher2 in forum General Help and How To
    Last Post: 12-13-2011, 02:01 PM
  2. Best way to reformat an SD card
    By Brettdacosta in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 03-08-2011, 09:16 AM
  3. Any way to prevent Gmail from syncing?
    By geneticfusion in forum HTC EVO 4G
    Last Post: 01-19-2011, 11:15 AM
  4. Replies: 2
    Last Post: 09-19-2010, 08:11 PM
  5. Any way to speed up the UI from SD loading?
    By boxta in forum HTC EVO 4G
    Last Post: 07-20-2010, 08:30 PM
