1. troutspinner's Avatar
    Title says it all. I hate cases but the camera lense protrudes out just a tiny bit compared to the cover. If I lay the phone on its back or even slide it across a counter (who am I kidding, the bar) will it scratch the lense? Or is the lense made of a strong glass like gorilla glass?
    Anyone had issues? And have you removed the piece of plastic that encircles the lense?
    05-22-2013 05:10 PM
  2. Paul627g's Avatar
    I would think this was a heavily tested part of the device in regards to common scratches, small drops and sliding around on the table, etc.. If you feel that you maybe doing damage to the lens then you may want to consider a thin case to beef it up a little..
    05-22-2013 06:16 PM
  3. felloffthetruck's Avatar
    Just got the S4 in today and it is one slippery sucker naked.
    05-22-2013 07:41 PM
  1. is it possible to disable the camera button?
    By shattuck in forum Motorola Droid X
    Last Post: 08-09-2015, 12:36 PM
  2. ways to protect the camera lens?
    By PaulWog in forum Samsung Galaxy S4
    Last Post: 06-06-2013, 08:57 AM
  3. Is there any app to rotate the camera live?
    By Rayz321 in forum Android Apps
    Last Post: 03-31-2013, 10:54 AM
  4. Is there a way to silence the camera?
    By Snareman in forum Verizon Galaxy Nexus
    Last Post: 12-10-2012, 11:19 PM
  5. Replies: 1
    Last Post: 02-15-2011, 07:24 AM
