1. cowbells's Avatar
    Which one are you usijg on this phone? I've always used light flow but and thinking that light manager might be a little bit better on this phone... Seems as if light flow is really draining the battery. What do you guys think? What are you using?
    Sent from my SCH-I545 using Android Central Forums
    05-27-2013 11:19 AM
  2. thedeceiver's Avatar
    I use light flow.. It works great except for the fact it makes my phone speak to me. I understand this is a limitation/bug on Samsung side but I don't know if Light Manager triggers the same behavior.
    Sent from my SCH-I545 using Tapatalk 2
    05-27-2013 07:57 PM
  3. Coffeeman's Avatar
    I use Light Flow as well. You can fix the bug in Light Flow that causes the phone to speak to you be going to "Settings--->My Device--->accessibility--->text to speech (change to Google), and turn light flow off, under "services". Light Flow will continue to work with these settings, but the phone will stop speaking to you.
    05-27-2013 09:13 PM
  1. Step by step Light Flow instuctions
    By Kale27 in forum Verizon Galaxy Nexus
    Last Post: 11-11-2012, 06:09 AM
  2. Replies: 54
    Last Post: 01-13-2012, 07:08 AM
  3. Some issues using Light Flow
    By XzombieX66 in forum Verizon Galaxy Nexus
    Last Post: 12-20-2011, 09:07 PM
  4. Light Flow
    By Hughey79 in forum Verizon Galaxy Nexus
    Last Post: 12-15-2011, 09:36 PM
  5. Photon LED (using Light Flow) after OTA update
    By latestGreatestPhone in forum Sprint Photon
    Last Post: 10-24-2011, 12:40 AM
