1. johnnyshinta's Avatar
    Who is using power save mode? I turned it off on my note 2 but have it on on my gs4 because it has a smaller battery. Anyone know if it makes a difference?
    05-27-2013 08:53 PM
  2. smalba's Avatar
    I've tried finding some answers on this but nobody has given a clear answer. I tested this mode myself with it on for a day and off for a day. Didn't tell a difference. I keep it off for now.
    05-27-2013 09:21 PM
  3. fantom305's Avatar
    It makes a difference because it reduces the consumption of battery by lowering the brightness and slowing the processor and turns off any other application that uses battery. I used it for a while when I had my S3 and tried it on my S4, but personally I don't like it. I prefer to have my phone full power and ready.
    05-27-2013 09:34 PM
  4. johnnyshinta's Avatar
    I figure if I'm not going to be able to charge it for a while then I might turn it on. Otherwise it's not necessary
    05-27-2013 10:02 PM
  5. johnnyshinta's Avatar
    So it turns out that the only time the cpu is limited is during game play or other times when the cpu would max out. Other than that the only difference is lower screen brightness which is a pain in the rear.
    So unless you want to limit your experience when you need the full force of your 1.9ghz quad core then why use this feature
    06-12-2013 03:36 PM
  1. Replies: 11
    Last Post: 12-25-2014, 04:58 PM
  2. Power Saving Mode
    By Murphy5111 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 01-04-2012, 05:23 AM
  3. Does Power Saving Mode.. Save Power?
    By MAGiK9 in forum Samsung Galaxy S II Skyrocket
    Last Post: 12-08-2011, 06:51 PM
  4. Power-saving mode questions
    By harry_fine in forum General Help and How To
    Last Post: 11-23-2011, 09:17 AM
  5. Power save mode useless
    By michaeljc70 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 11-03-2011, 01:34 PM
