1. dimsdale's Avatar
    I have the 16GB VZW S4 right now. I'm thinking of returning it and waiting for the 32GB to drop.
    But I can't figure out if I will need the extra MB. I have a 64 GB SD card in the phone now, full of movies and mp3s.
    I have installed just about every app that I would naturally use and still have 7.72GB of free space.
    How am I going to fill that space? Angry Birds average less than 50MB. In 7.00 GB, I could install 140 copies of Angry Birds.
    Are there games that are 500 MB out there?
    05-28-2013 12:04 PM
  2. ibcop's Avatar
    Yes, there are.....but if you have installed everything you'll use, you should be good to go. I am with Verizon as well and waiting for the 32gb S4 (if there will be such a thing) - I have the 32gb S3 and don't want to go down in size. But that's a personal preference thing for me. I also use the 64gb card.
    Modern Warfare is right at 1.75gb in size.
    05-28-2013 12:13 PM
  3. dimsdale's Avatar
    I see Modern Combat 4 is at 1.90 GB.
    That will do it.
    05-28-2013 12:35 PM
  4. paintdrinkingpete's Avatar
    It's primarily HD games, like those converted from console systems.
    Unless you're into that sort of thing, honestly, 16GB is probably enough for most people. For those that do enjoy games, however, that 16GB can go really quick.
    05-28-2013 01:18 PM
  5. garublador's Avatar
    If I'm not mistaken, some, if not all, cloud storage music services only allow you to "pin" music to internal storage. If you plan on using that feature and have more than a couple gig of music then 16gig might not be enough. If you just synch your phone with a music manager or drag and drop your music files to your phone you can use the SD card.
    05-28-2013 02:36 PM
  6. paintdrinkingpete's Avatar
    Google Music does only allow you to "pin" music to internal storage, yes, but if you manually add music files to your SD card, the Music app will see it.
    Sent from my Nexus 10 using Tapatalk HD
    05-28-2013 09:09 PM
  7. zog1977's Avatar
    I don't think a 32 gig is needed. Plus, I don't play games on my phone. That is why I have an iPad.
    To me it's just not worth it. I am happy with my 16 gig
    05-28-2013 09:12 PM
  8. rushmore's Avatar
    I probably would agree in this case, but I want a 32GB S4 and also have an iPad 4- 128gb. Yes, too much iPad for most.
    05-28-2013 09:22 PM
  9. zog1977's Avatar
    Yes I do agree. Too much iPad. Lol
    05-28-2013 09:37 PM
  10. dimsdale's Avatar
    If MSFT came out with Office for Android, that could be a big app and might push people to want more internal memory. But even still, how big could that be. They would feature limit it anyway to keep it from being too good - even if they did offer it.
    Couldn't be more than 500 MB. Prolly 250.
    05-31-2013 07:28 AM
  11. prley's Avatar
    I waited for the AT&T 32 gig version before getting mine. I have a 64 gig sd card installed. I would probably got the 16 gig if that was all that's available. but for $50 double internal memory is a no brainer for me.
    05-31-2013 09:17 AM
  1. Nexus 10: 16gb vs 32gb
    By Max Heller in forum Google Nexus 10 Tablet
    Last Post: 06-05-2013, 01:55 PM
  2. Replies: 9
    Last Post: 11-26-2012, 10:11 AM
  3. 16gb or 32gb version? Which do I need?
    By davidp007 in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-12-2012, 04:57 PM
  4. 16gb Vs 32gb + sd card....what am I missing here???
    By racermech in forum Verizon Galaxy S III
    Last Post: 09-22-2012, 08:46 PM
  5. galaxy s III .... 16GB VS 32GB
    By eric0668 in forum T-Mobile Galaxy S III
    Last Post: 07-18-2012, 01:03 AM
