1. wallstreet123456's Avatar
    I have my notification volume set at one level above vibrate but when I receive a text it still is very loud. I don't want it as loud as it currently is but I am not sure how to lower it without muting it?
    Any ideas what I might be doing wrong?
    05-29-2013 09:26 AM
  2. Golfdriver97's Avatar
    At first I thought there was a separate notification volume for texts, but I looked under settings in messaging on my S3, and I don't have that. You can try that, but I doubt it's there either. So, now I am under the impression that it is the volume which the sound was recorded. Try a quieter ringtone, ask a friend to send you a test text. If it changes, then that's it. If not, I have no idea what to try next.
    05-29-2013 09:33 AM
  3. SpookDroid's Avatar
    It could be that the notification file you've selected is really loud (I know I used to have one of those for my text messages originally). But you can also set volume levels for Music/Media, Ringtone, Notifications, and System sounds. Just press the Settings button that appears when you turn volume up/down or pull down on the notification bar and long-press the Sound Mode toggle and go into Volume.
    05-29-2013 10:12 AM
  1. Notification volume keeps moving to Full
    By danharmon in forum Motorola Droid
    Last Post: 08-21-2010, 09:16 AM
  2. Ringer/notification volume randomly going to high?
    By amandafaye in forum Motorola Droid
    Last Post: 08-21-2010, 09:07 AM
  3. Notification volume while charging
    By gskbrew in forum HTC EVO 4G
    Last Post: 07-23-2010, 01:43 AM
  4. Change notification volume?
    By sillyshyme in forum Verizon Droid Incredible
    Last Post: 06-07-2010, 02:11 PM
  5. easily adjusting notification volume
    By jzarowitz in forum General Help and How To
    Last Post: 04-06-2010, 10:36 AM
