1. adamant117's Avatar
    What's the little eyeball looking icon on top of the screen 4?
    Sent from my SCH-I545 using Tapatalk 2
    05-29-2013 10:18 AM
  2. Odd Future's Avatar
    It means smart stay or smart scroll is activated
    Sent from my SPH-L720 using Android Central Forums
    05-29-2013 10:20 AM
  3. SpookDroid's Avatar
    What Odd Future said. And that also means IT'S LOOKING AT YOU (Literally). It should only pop-up when you can actually use that feature (either smart-stay or smart-scroll). In places where you can't use it, the icon should go away (the icon in the middle, not the notification tray icon). BTW, you can turn off the icon feedback. The feature will still be active, but you won't see the creepy eyeball pop-up all the time (again this is the middle-screen pop-up, not the icon on the notification bar area)
    05-29-2013 10:27 AM
  1. OK, do the LED lights next to the camera work at all?
    By nikeairs23 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-25-2011, 10:46 PM
  2. Replies: 0
    Last Post: 06-22-2011, 10:23 AM
  3. Little advice on moving to the Thunderbolt
    By joey0480 in forum Verizon HTC Thunderbolt
    Last Post: 04-16-2011, 01:43 PM
  4. What are those "light, Camera" things next to the front earpiece?
    By jjcasillas15 in forum Verizon Fascinate
    Last Post: 10-04-2010, 08:10 PM
  5. Next to the Hoover Dam?
    By c4v3man in forum Motorola Droid X
    Last Post: 06-30-2010, 12:20 PM
