1. kyle0k's Avatar
    So initially my s4 was so so in battery life but from what I remember I never had lag and everything always responded instantly. Fast forward a week and I factory restored the phone and started over. With a combination of common sense techniques and utilizing better batter plus, the battery is stellar. However now the problem is a very noticeable lag.
    Anyone have any tips on how to diagnose what's causing this? I can kill all tasks with a task killer and it still does it, so it's nothing that simple.
    05-30-2013 12:06 AM
  2. onick's Avatar
    As far I understand, when you use the built in power saver mode or similar programs, the cpu is under clocked to save battery. It might explain the lag you are facing.
    Sent from my GT-I9100 using Android Central Forums
    05-30-2013 02:50 AM
  3. urstrinath's Avatar
    For lagging problem
    clear the running apps every time & download battery doctor on your phone.it will automatically makes your phone faster
    05-30-2013 03:24 AM
  4. Almeuit's Avatar
    I'd say it's this. Power saving stuff will underclock things.
    Sent from my Sprint S3 using AC forums.
    05-30-2013 05:54 AM
  5. Rick Bray's Avatar
    For lagging problem
    well, this is something that i disagree, but not completely..... you should NOT kill running apps, UNLESS they are hanging there, or running in the background really bad....
    05-30-2013 07:09 AM
  6. kyle0k's Avatar
    I didn't do any power saving stuff like slowing the phone down.... I meant I made sure not to have any programs that were sucking battery and turned off all the settings that require constant GPS attention and stuff like that. I didn't turn on battery saver mode or anything.
    Rick Bray, how do you tell the difference between an app that's just idle in the background or one that's hanging there.....
    I found an app that I think might have caused a lot of the lag however. Its the "es file viewer" It randomly crashed, while I wasn't even using it. Then the phone became a little snappier. I use it everyday, a couple times a day. So its usually in the background. Could be part of the problem....
    Any program out there that monitors programs and background programs to see how much CPU they use.
    05-30-2013 11:27 AM
  7. Almeuit's Avatar
    I think better battery stats does.
    05-30-2013 11:59 AM
  8. Rick Bray's Avatar
    what i usually do is to take a look at battery stats to see if any app is using much battery, but it would be easier to download an app to monitor ram/cpu (i use ZDbox), and there you can see if an app is using waaay too much CPU.....(that app may be hanging instead of just idle)
    i usually stop those, and if it recurs, i uninstall it and try to find an alternative....
    works for me, and my S4 goes pretty smooth all the time
    05-30-2013 12:04 PM
  9. Joe_Perone's Avatar
    Click your home button twice to bring up S-Voice, then go to the settings in that app and uncheck the use with Home button option. This removes some Touchwiz lag. Also, activate developer options in your settings app, and turn down the animations from 1.0 to 0.5 or none. This gets rid of 95-99% lag.
    05-30-2013 01:05 PM
  10. tohio's Avatar
    Have you installed the latest update?
    05-30-2013 01:13 PM
  11. Joe_Perone's Avatar
    Was there one today?
    05-30-2013 01:32 PM
  12. tohio's Avatar
    No, the one released May 7th.
    05-30-2013 01:52 PM
  13. Joe_Perone's Avatar
    Oh okay, nevermind then
    05-30-2013 02:04 PM
  14. Infinity's Avatar
    Are you using swiftkey? People have reported that most of the lag went away when they uninstalled swiftkey.
    05-30-2013 02:52 PM
  1. Disable Bluetooth for Media but not Phone Calls?
    By eKennedy#AC in forum HTC EVO 4G
    Last Post: 12-27-2012, 08:24 PM
  2. Replies: 8
    Last Post: 09-17-2010, 01:24 PM
  3. Battery Profile = Great Battery life!!!
    By GynormousMellon#AC in forum Motorola Droid X
    Last Post: 08-21-2010, 07:54 AM
  4. Replies: 10
    Last Post: 06-08-2010, 02:18 PM
  5. Replies: 10
    Last Post: 05-21-2010, 06:51 PM
