1. Joe_Perone's Avatar
    I asked this in general, but perhaps it's better suited here:
    I just downloaded this app, and I noticed that in the notification bar, the little droid is only green when I have wifi, data, or bluetooth on. Is the app only saving battery while those are on? Anyone else have experience with this app to tell me? Also, is there an even better app than this, perhaps one that uses less CPU and RAM? And that can actually SHOW me it's working? I'm really going by number of downloads in Play, which isn't always the best indication of a good app. It's really just for emergencies, because I don't really need a battery saver, but it's good to have one just in case.
    Also, for other users of this app, if I do keep it, the highest I can get it to save on the notification screen is 1.6x. I use the advanced customizable setting. Are there optimal settings to increase that number? Thank you so much!
    05-30-2013 09:44 AM
  2. Joe_Perone's Avatar
    Bump please :-)
    05-30-2013 10:23 AM
  3. MilgeS's Avatar
    Hi,
    I use this https://play.google.com/store/apps/d...51bGwsMSwyLDNd
    and have also bought the Ultimate version https://play.google.com/store/apps/d...1hdGVqdWljZSJd
    However, I'm currently using this, https://play.google.com/store/apps/d...mFnb24uYXBwIl0.
    I'm giving it a go for a week as it 'learns', JD gave me nearly 2 days of average use before I installed this Snapdragon app.
    Hope that helps
    05-30-2013 10:53 AM
  4. tsells's Avatar
    The best way to save your battery is not to buy any app that uses the battery! I do not believe that any battery optimization app is needed on any Jelly Bean phones.
    There are lots of threads on how to save battery and they include things like lowering screen brightness, turn off wifi and bluetooth when not using them, increasing the amount of time that apps update (i.e. weather, email, etc). You should be able to get a full day out of your device (unless you are in a poor reception area) without using any app to help.
    20blks and Joe_Perone like this.
    05-30-2013 11:14 AM
  5. thegrants82's Avatar
    You can go an extra 20%+ with the right app. I have added over an hour with snapdragon battery guru alone. This app is written by the same guys that make our processor. Try it because it works very well.
    05-30-2013 11:22 AM
  6. Joe_Perone's Avatar
    I don't have the patience to wait for Snapdragon to "learn", and apparently the increase isn't too huge. Maybe I'll just uninstall this booster app I have, meh. Oh well. I guess phones this advanced don't really actually need one.
    If the Snapdragon one actually works, I'll use it.
    05-30-2013 11:46 AM
  7. Joe_Perone's Avatar
    Hi,
    Hope that helps
    Well, on average, before I installed the app, I got like 63-65 hours of usage out of the phone. So really, it's a "just in case" app more than anything.
    05-30-2013 11:49 AM
  8. Joe_Perone's Avatar
    UPDATE: I erased the Easy Battery Saver and I'm giving the Snapdragon BatteryGuru a try, might as well :P
    05-31-2013 06:55 AM
  9. redrover69's Avatar
    Any results on snapdragon???
    10-01-2013 10:51 AM
  1. Easy Battery Saver App killed my data, now can't get back
    By rolo99 in forum Verizon HTC Thunderbolt
    Last Post: 07-31-2012, 09:31 PM
  2. No service, and another question??
    By billcosby41 in forum HTC myTouch 4G
    Last Post: 10-05-2011, 05:52 PM
  3. battery savers and task killers
    By ryokox3#AC in forum Motorola Droid X
    Last Post: 05-14-2011, 03:17 PM
  4. best battery saver and app killer apps?
    By Brad48 in forum HTC myTouch 4G
    Last Post: 03-01-2011, 04:38 PM
  5. /system/xbin user created? and another question...
    By ikith in forum Software Development and Hacking
    Last Post: 01-01-2010, 06:21 PM
