1. Rudolphe's Avatar
    Is it possible to change the home button to double click for multi task? Or at least speed up how long you have yo hold home to bring up the multitasking options?
    Thanks!
    05-31-2013 01:39 PM
  2. Joe_Perone's Avatar
    Thanks!
    Turn off the S-voice to make it faster. Go into S-voice > Settings > disable for home button.
    The reason the home button on the whole is slow is because it waits for you to click the button twice, since it *wants* you to use S-voice. Siri causes the same problem on iOS I find.
    05-31-2013 01:40 PM
  3. Rudolphe's Avatar
    Thanks, but that isn't what I'm looking for. Even with S voice off you have to hold the home button in order to open multitasking. I want to be able to double tap home or decrease the delay for opening multitasking.
    05-31-2013 01:52 PM
  4. Joe_Perone's Avatar
    I found that for me, the delay was decreased for multitasking after that. Perhaps they'll fix it in 4.1.3
    Maybe settings > accessibility?
    05-31-2013 01:55 PM
  1. READY TO SPEAK Google Now with Home button Double Click here
    By Kelly Kearns in forum AT&T Galaxy S III
    Last Post: 02-18-2014, 11:05 AM
  2. Multi-tasking question
    By dornier in forum HTC Hero
    Last Post: 04-08-2013, 05:20 PM
  3. Double tap home button for S-Voice.
    By my3chis in forum Verizon Galaxy Note 2
    Last Post: 12-06-2012, 11:00 AM
  4. HTC One X + for AT&T multi-tasking issues....
    By smartvoyager in forum HTC One X
    Last Post: 11-20-2012, 10:24 AM
  5. Double tapping home button for new function?
    By darigaaz12 in forum Samsung Galaxy S3
    Last Post: 07-03-2012, 11:22 PM
