1. swent1's Avatar
    Is there any widget or app that allows lock screen widgets and customization while it is password protected?
    Sent from my Samsung Galaxy S4 Android Central Forums
    05-31-2013 10:50 PM
  2. planoman's Avatar
    Are you talking widgets or the app shortcuts. I use a pin and use the app shortcuts. I have my PIN timer set to 10 minutes and except for when I have to use the PIN it works fine. Once the screen times out after 30 seconds and I press the home button to bring up the lock screen the app shortcuts are there and I can swipe to open them. I do not use widgets but I am sure you could.
    05-31-2013 11:31 PM
  1. Music widget/bar on lock screen (how to remove)
    By moonrun in forum Samsung Galaxy S4
    Last Post: 05-29-2016, 09:19 PM
  2. Replies: 18
    Last Post: 09-18-2013, 03:07 PM
  3. Replies: 4
    Last Post: 05-23-2013, 01:57 AM
  4. Adding a widget to the lock screen
    By DroidN3WB in forum Samsung Galaxy S3
    Last Post: 01-04-2013, 10:40 AM
  5. How to change lock screen icons on widget locker on SGS3?
    By Soundtrack to Chaos in forum Samsung Galaxy S3
    Last Post: 08-04-2012, 01:39 AM
