04-17-2018 12:53 PM
75 123
tools
  1. j510's Avatar
    Open camera app. Menu key. Settings. Settings tab. Scroll all the way to the bottom. Shutter sound off. Arr you on the latest update
    08-02-2013 06:29 AM
  2. Almeuit's Avatar
    I think only some carrier versions have this.
    Sent from my T-Mobile HTC One using AC Forums.
    msndrstood and klemen10 like this.
    08-02-2013 08:46 AM
  3. Alastair See's Avatar
    the option only display one box saying disable enforcer something,... no camera sound... how...?
    08-02-2013 12:13 PM
  4. kingb71's Avatar
    I've noticed on mine, if the phone is in silent mode, there is no shutter sound. Could be a quick work around.
    08-02-2013 12:31 PM
  5. Radd3x's Avatar
    I tried the app that was linked above on my GS4 and it worked like a charm. Download it, open it, and check the box next to "Disable STREAM_SYSTEM_ENFORCED."
    I also want to confirm that the Verizon version of the GS4 (which is the version that I have) doesn't have "Shutter Sound" listed as an option under the camera settings. Hence, the need for the app.
    08-11-2013 10:14 PM
  6. Cachinbon69's Avatar
    I have a Samsung Galaxy Note 2 and I can't get rid of the Shutter Sound it drives me crazy
    08-17-2013 04:13 AM
  7. Bester John's Avatar
    If you want to remove it completely, try this app. It worked on all my previous phones.
    This apps work great on my note 2 n7105. Now i can take pic w/o putting my phone on silent mode.
    https://sites.google.com/site/enforcedstreamsilencer/
    You're welcome.
    08-19-2013 01:48 PM
  8. mysticmeg's Avatar
    Wait a minute. My s4 doesn't have a shutter sound because I have it in vibrate mode and that turns of any notification sounds even the shutter sound. So why on earth are people download apps for their phone when the shutter sound can be turned off by muting the notifications sounds.
    Sent from my GT-I9505 using Tapatalk 2
    08-19-2013 03:04 PM
  9. Arvidolos's Avatar
    You're welcome.
    does it not harm my Phone If I install it? 100% sure? beacuse If I get and problem with it I'm gonna be so sad.. (new galaxy s4)
    09-12-2013 04:37 PM
  10. Eonez Rizuan's Avatar
    what else does this app affects on?
    otr than cam?
    btw...thx a lot...just want to understand the side effect of the app
    10-03-2013 11:33 PM
  11. awlycoris's Avatar
    On a samsung S3 how to turn off the shutter sound. I have tried everything and can't get the sound off any help at all would be nice thanks
    10-04-2013 06:05 PM
  12. edgefever's Avatar
    Only way is,, put on silent or vibrate
    10-04-2013 09:08 PM
  13. JudH's Avatar
    One solution I'm surprised nobody has mentioned that should work on all carriers--install a 3rd party camera app and just don't use the original app. They ALL should have the option to silence the shutter sound. There are several in play store.
    10-04-2013 10:36 PM
  14. dmiller1#AC's Avatar
    Do I need a specific root explorer to use this? I tried through es file explorer with no luck. Any help would be appreciated.
    10-05-2013 09:17 PM
  15. hashtagkasia's Avatar
    Thank you so much! Its been so irritating on my s3! Thanks again
    10-17-2013 07:34 PM
  16. Shanicenicolle's Avatar
    Doesn't work on the s3 or the s2 (I spent extensive time trying on my coworkers phones Lol) you have to download an app
    Sent from my *PURPLE* Galaxy S4
    10-17-2013 07:54 PM
  17. erikerikerik's Avatar
    You're welcome.
    Woot thx, worked here also!
    10-27-2013 08:42 PM
  18. mhinc's Avatar
    There is an entire thread already for this, why can't people search?
    10-27-2013 08:43 PM
  19. skidoo's Avatar
    Free tech support is an "externality," in economic terms. "Free" as in beer. And someone else is doing the brewing.
    ___
    Posted via mobile.
    10-28-2013 07:48 AM
  20. sziloti's Avatar
    You're welcome.
    Thank you. It work.
    11-01-2013 02:55 AM
  21. Michael Myers4's Avatar
    Doesn't work
    12-31-2013 08:36 AM
  22. Lorena Gutierrez's Avatar
    01-05-2014 04:25 PM
  23. kmunasinghe's Avatar
    doesnt work dude
    01-07-2014 05:45 AM
  24. mwrmt's Avatar
    I don't have the sound option on mine either and I'm on Telus(Canada).
    I did switch to Camera ZOOMFX and have that option.
    01-07-2014 10:33 AM
  25. najhum's Avatar
    Try a simple solution put your index finger on the speaker at the back of the device and it will almost mute the sound
    01-08-2014 01:51 AM
75 123
  1. How to turn off camera shutter sound
    By Pre-Occupied in forum HTC One M7
    Last Post: 05-27-2015, 02:29 PM
  2. Here is how to turn that camera shutter sound off.
    By Paladin in forum HTC EVO 4G LTE
    Last Post: 05-08-2015, 09:30 AM
  3. How To Mute Camera Shutter Sound Finally On Rooted Wildfire S
    By NisarSoomro1 in forum HTC Wildfire S
    Last Post: 04-17-2013, 06:06 AM
  4. how to turn the shutter sound off?
    By madilinerosie in forum LG Optimus Elite
    Last Post: 09-19-2012, 09:50 AM
  5. How to turn camera sounds off.
    By Rob3rd in forum Motorola Droid X
    Last Post: 07-21-2010, 10:34 PM
