04-17-2018 12:53 PM
75 123
tools
  1. dyerdiehl's Avatar
    I have a Verizon phone and don't have the option to silence the shutter sound. I made an easy Tasker profile that solved the problem. Works like a charm. Profile- when camera app is loaded, Task- shift to silent mode and when leaving camera app, return to normal volume.
    How to remove camera shutter sound? Thanks!
    dimm0k likes this.
    01-08-2014 11:57 AM
  2. joeaub's Avatar
    When I clicked on the link a pop up at the bottom came up that says:
    This type of file can harm your device. Do you want to keep it anyways?
    Should I be afraid? I've only had this phone for 4 days. I don't want to screw it up. I just came from an iPhone 5 and I really liked the ease of silencing the shutter on it.
    01-13-2014 12:54 AM
  3. kardot's Avatar
    Hi
    EnforcedStreamSilencer .apk
    This did not work in Galaxy Note 3 (Australia Version)... Camera shutter sound still occur.
    01-14-2014 12:14 AM
  4. ally18's Avatar
    EnforcedStreamSilencer .apk worked on my s4
    01-15-2014 04:16 PM
  5. ecuthbertson's Avatar
    Did not work either on my Galaxy s4 Australia
    01-16-2014 05:44 PM
  6. John Steven Bucio's Avatar
    why it is 15 kb it is realy work
    01-24-2014 08:38 AM
  7. clownin72's Avatar
    Thank goodness. The link worked for me as well. S4 on Verizon
    01-24-2014 11:30 AM
  8. kmcj's Avatar
    Thank you - the link worked on my S4 on the Verizon network.
    02-05-2014 03:25 PM
  9. Michael Blott's Avatar
    Thank you. Worked for my Galaxy 3
    If you want to remove it completely, try this app. It worked on all my previous phones.
    https://sites.google.com/site/enforcedstreamsilencer/
    You're welcome.
    02-08-2014 03:46 PM
  10. Geoffh3's Avatar
    Thanks for the link to the APK. Works great on Verizon S4.
    02-20-2014 11:43 AM
  11. matthelldoerfer33's Avatar
    02-21-2014 10:53 AM
  12. altwkt13's Avatar
    It worked on my Verizon Galaxy S4. Thanks a ton!
    03-02-2014 07:58 PM
  13. icheckthissometimes's Avatar
    Thanks this worked great on my (unfortunately recently 4.3 updated) GS3 that previously had no way to turn off - other than volume, which was a pain when I wanted to snap a quick silent shot of the kids.
    <rant>
    Can't believe there are laws that require a phone to make a sound when snapping a picture! Aren't those the same countries/provinces that have surveillance cameras everywhere and you assume that you're being video'd/photo'd anyway 24/7? And back in the day, regular cameras kept improving the shutter sound to get as silent as possible, now we have the reverse with cameras that make no natural shutter sound!
    </rant>
    03-06-2014 12:03 PM
  14. edwinengel's Avatar
    Worked like a charm on a Samsung S4 mini. Thank you
    04-05-2014 08:35 AM
  15. jeaves726's Avatar
    For verizon, the shutter sound is tied to the ringer volume. If you mute the ringer, the camera sound will be muted too.
    04-06-2014 11:51 AM
  16. Magnustampa's Avatar
    Yeah, for those who think it is so easy, it is not. My LG Optimus G (Sprint) has NO option to disable it. It sounds, loudly, in ALL volume settings (including vibrate only, and full silent), sounds even with headphones plugged in, and while finger over the speaker muffles it well, it is still pretty damned loud. The only option in camera app is to change the sound, but not to disable it. Short of rooting it, that is. I also just tried Enforced Stream Silencer, no effect, again in any volume mode. But, it does seem that using other apps works. I am now trying Silent Camera, which has good reviews, but also is crashing like crazy (when trying different shooting modes) and requires full phone reboot after.
    04-10-2014 02:07 PM
  17. mhinc's Avatar
    OMG This again! There is a HUGE thread already for this, at like 13 pages long. Please search before posting the SAME thing over!
    04-10-2014 03:46 PM
  18. oscar cors's Avatar
    TEST Y300 HUAWEI
    Using Root explorer Raiz
    SYSTEM
    MEDIA
    AUDIO
    UI
    rename the files and the sound camera off
    You can rename the video sound files too
    05-20-2014 11:45 AM
  19. bugmenot211's Avatar
    There's a patched samsung camera apk at xda, buy apparently you need a deodexed rom for it to work:
    [HOW TO] Remove camera sounds. ROOT REQUIRED
    [MOD][UPDATE FOR MEA] Camera no sounds (root required) - uploaded
    There's also the CameraMute that mutes your phone at the precise moment of taking the picture, but only selected devices are compatible:
    [APP] Camera Mute Version 1.5 (11-19-13) - Mute your camera shutter without
    The method of renaming ogg files under /system/media/audio/ui doesn't work anymore because the sound files are included in the apk itself.
    05-23-2014 01:33 PM
  20. Dark Penguin's Avatar
    If the phone is rooted... goto root > system > media > ui
    Under ui , rename the files shutter.ogg to anything eg shutter_no.ogg
    do the same for camera...
    Reboot....
    Voila!!!! No camera sounds...
    Enjoy!
    Sent from my GT-I9500 (Hassan Khalid Malik) using Tapatalk 2
    I have a slightly earlier model (S2 - rooted), and the camera shutter sound consists of a beep followed by a loud click. I followed the steps above, and the click is gone--great! But the beep is still there; how do I get rid of that?
    This single beep sound also happens when touching the screen to focus on a particular object in the frame, but I can't find any .ogg files in the /ui folder that seem to take care of this.
    06-15-2014 02:57 PM
  21. Fcm1014's Avatar
    That link didn't work for my shutter sound...instead it turned my phone on mute.
    01-16-2016 06:57 PM
  22. Rukbat's Avatar
    For anyone thinking of doing this, please remember that it's actually illegal in some places to take a picture without some sort of shutter sound (and you can be arrested for it). Check your local laws before turning it off.
    01-16-2016 09:17 PM
  23. sccservice's Avatar
    Open your camera app, click the little settings gear at the top, scroll down and uncheck "shutter sound"
    01-16-2016 09:27 PM
  24. Felix Kattah's Avatar
    Worked great!! Thanks .
    09-09-2017 10:05 AM
  25. Tommyig's Avatar
    I hit my volume down arrow it showed ringtone turned down so I hit the arrow to the right to open more volume controlled. D turned everything down , it was the only method that worked even silent cling the phone didn't help
    04-17-2018 12:53 PM
75 123
  1. How to turn off camera shutter sound
    By Pre-Occupied in forum HTC One M7
    Last Post: 05-27-2015, 02:29 PM
  2. Here is how to turn that camera shutter sound off.
    By Paladin in forum HTC EVO 4G LTE
    Last Post: 05-08-2015, 09:30 AM
  3. How To Mute Camera Shutter Sound Finally On Rooted Wildfire S
    By NisarSoomro1 in forum HTC Wildfire S
    Last Post: 04-17-2013, 06:06 AM
  4. how to turn the shutter sound off?
    By madilinerosie in forum LG Optimus Elite
    Last Post: 09-19-2012, 09:50 AM
  5. How to turn camera sounds off.
    By Rob3rd in forum Motorola Droid X
    Last Post: 07-21-2010, 10:34 PM
