1. wechan91's Avatar
    I just got my s4 a couple days ago and I notice that whenever I use the wall charger/adapter and USB cable provided in the box, my phone says that it is charging via USB charging as opposed to AC charging. Under this setting it takes my phone over 5 hours to charge fully and I feel like something must be wrong. Any suggestions as to what to do?
    06-01-2013 10:24 AM
  2. friedtators's Avatar
    5 hours is not to long
    06-01-2013 10:30 AM
  3. wechan91's Avatar
    Should it say AC charging instead of USB charging though?
    06-01-2013 10:40 AM
  4. ddsdavid's Avatar
    Mine will say AC charging.
    Sent from my SCH-I545 using Android Central Forums
    06-01-2013 10:52 AM
  5. Thegreatone3's Avatar
    Five hours is too long. Even my Razr Maxx with its 3,300 mAh battery charges from dead in about three hours.
    06-01-2013 10:53 AM
  6. Love Divine's Avatar
    Yup, thats a known bug. My only suggestion is to not let the battery get much below 10%. Also, just unplug and replug till you get it to say AC. That will cut charging time by about 3 hours.
    06-01-2013 11:26 AM
  7. dimsdale's Avatar
    Thx. Do you remember / can you say where else this AC/USB charging issue was discussed?
    06-01-2013 11:55 AM
  8. Love Divine's Avatar
    There's a thread on this forum... "Battery not charging" or something like that.
    06-01-2013 02:43 PM
  9. thegrants82's Avatar
    5 hours is twice as long as normal.
    06-01-2013 02:56 PM
  10. iFortWorth's Avatar
    With my OEM charger, my S4 is taking about 9 hours to charge from 5-10% back to 100%.
    Is this a defect with my device, the charger, or something else?
    Thanks
    David
    06-01-2013 04:19 PM
  11. mnsrhjr's Avatar
    unplug and replug the charger until it says AC rather than USB really did work on my S4. i did it in one try thou
    09-20-2013 08:37 AM
  1. Anyone else having problems with AC Site & Chrome on PC?
    By dorelse in forum Site Feedback & Help
    Last Post: 11-15-2012, 11:18 AM
  2. Problem with Android Market on HTC Wildfire
    By Nouty in forum General Help and How To
    Last Post: 08-23-2010, 02:25 PM
  3. Please Help!: Problem with replacing phone on 30 day warranty
    By thewaterballoonist in forum HTC EVO 4G
    Last Post: 07-14-2010, 11:26 PM
  4. Problem with SD Card on Custom ROM's
    By clsiburt in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-13-2010, 12:54 PM
  5. problems with google talk on 2.1(v2)
    By pursuitofhappiness in forum HTC Droid Eris
    Last Post: 03-30-2010, 10:36 PM
