06-02-2014 11:49 PM
26 12
tools
  1. Gabriel Wong's Avatar
    I can help you with this. The Samsung galaxy note 2 has a NFC and Beam on the surface of the case of note 2 (near the camera) while the S3 or S4 has them built in with the battery. If you are not using the legitimate battery then u might not be able to use this feature. Just get the two phones as near as their NFC and Beam then you will be able to use this feature.
    06-02-2014 11:49 PM
26 12
  1. Does the S4 work with the Fitbit Flex?
    By Slow_S10 in forum Samsung Galaxy S4
    Last Post: 05-16-2013, 09:02 PM
  2. Does the LED work with WhatsApp?
    By katesbb in forum Droid RAZR MAXX HD
    Last Post: 02-28-2013, 09:07 PM
  3. does hotspot stay on the phone with temp rooting?
    By smokinHawk in forum Rezound Rooting, ROMs, and Hacks
    Last Post: 12-27-2011, 12:57 PM
  4. Does the jig work with the Galaxy Nexus?
    By bboykin87 in forum Verizon Galaxy Nexus
    Last Post: 12-14-2011, 12:16 PM
  5. Replies: 7
    Last Post: 07-19-2010, 09:14 PM
