1. Yellowfddriver's Avatar
    I'm sure this has been posted before (but while studying for the bar, I don't have a lot of trolling time ;( ) or maybe it hasn't but...
    There's either a problem with Google Maps, Google Services or maybe Sammie SW? I still get like ~1day per battery, but after seeing some of the stellar battery life numbers that some people have posted, I figured this has to be wrong. I checked Battery under setting and whatdayaknow, Maps is usually taking more battery than Screen sometimes!
    Is anybody else experiencing this? Any fixes? Is this a Google issue maybe...and a glitchy version of maps/services framework?
    Thanks!
    P.S.: I've noticed this fairly recently.
    06-01-2013 08:08 PM
  2. scorpiodsu's Avatar
    Thanks!
    2 things to check
    1. If location settings is enabled in Tue main settings then Google maps will run intermittently.
    2. In the maps app go to settings>kocatin settings and turn off location reporting and location sharing. This will increase the number of times maps run in the background if location settings are enabled.
    I have location settings enabled but I turn of location reporting and sharing so maps uses little of my battery.
    Sent from my HTC One using Android Central Forums
    06-01-2013 08:51 PM
  3. Yellowfddriver's Avatar
    I'll try that out, but something tells me this is a google issue. Will update.
    06-02-2013 08:13 AM
  4. JGouse0498's Avatar
    Got my S4 yesterday morning and found that early this morning (I work nights, so about 3:30 am) Maps had overtaken Screen as the highest percentage (35-40% for Maps). I found that Maps had kept my phone awake for nearly an hour overall. I did notice that location reporting was turned on, so I have turned it (leaving Location Services on since I use Google Now). It's currently recharging so hopefully the next 24 hours will tell whether or not Location Reporting was the culprit.
    06-02-2013 12:58 PM
  1. Maps battery drain?
    By ghostkilla1388 in forum Sprint Galaxy Note 2
    Last Post: 05-09-2013, 04:20 AM
  2. [HOW TO]Google maps battery drain fix
    By MasterTec in forum Virgin Mobile Optimus V
    Last Post: 05-03-2013, 03:11 PM
  3. Nexus 4 maps battery drain
    By nexuser in forum Google Nexus 4
    Last Post: 04-03-2013, 01:42 AM
  4. HELP. Google Maps Battery Drain
    By vg7702 in forum Sprint Nexus S 4G
    Last Post: 12-21-2011, 12:29 PM
  5. Google Maps....Battery Killer?
    By regime2008 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 08-02-2011, 02:41 PM
